Calgary - random talk thread
Old 08-05-2008, 02:35 AM
  #4201
cruisn's Avatar
Originally Posted by Banzai2.4
wooot
jus installed my ZZP header/dp and megan catback
i need a tune mark and my wideband hooked up.. haha
did they dp fit okay? I figured I lined it back up pretty clsoe
Old 08-05-2008, 10:50 AM
  #4202
DoubleLP's Avatar
Originally Posted by Pickles
Has anyone installed a mechanical boost gauge? I picked one up, but I haven't got a clue how to splice the tiny vac hose into a main hose, or the best way to route it...
Hey Mark......I can come by and you can see where I installed my sending unit. They are the same whether it is the electric or the mechanical boost gauge.
Old 08-05-2008, 11:29 AM
  #4203
Banzai2.4's Avatar
yea it worked awesome, i need a different catback tho... my megan is made for a cobalt so its really short and sitting awkwardly...
Old 08-05-2008, 04:02 PM
  #4204
tkaugh29's Avatar
its really simple just cut the vaccum hose and put a T-fitting in. then attach the vaccum hose back to both sides of the t fitting and with the remaining side of the t-fitting just attach the hose from there to the back of the gauge and voila! just like everybody else id reccomend getting the braided hose and t-fitting from mopac, it looks alot better and works better then the silicone one. i think i still have all the part numbers if you need them
Old 08-05-2008, 04:13 PM
  #4205
Banzai2.4's Avatar
i can haz boost??
Old 08-05-2008, 04:18 PM
  #4206
Pickles's Avatar
Originally Posted by tkaugh29
its really simple just cut the vacuum hose and put a T-fitting in. then attach the vacuum hose back to both sides of the t fitting and with the remaining side of the t-fitting just attach the hose from there to the back of the gauge and voila! just like everybody else id recommend getting the braided hose and t-fitting from mopac, it looks alot better and works better then the silicone one. i think i still have all the part numbers if you need them
Sweet. That's something I seem to remember reading a while back that the stock hose cracked easy or something.
Thanks for the infos trav.
i can haz boost??
WOOT WOOT!!!!
Old 08-05-2008, 04:32 PM
  #4207
Banzai2.4's Avatar
u know it
BIG 16G
Old 08-05-2008, 05:07 PM
  #4208
Pickles's Avatar
u know it
BIG 16G
Geez bud. Won't that be hella turbolag?
Old 08-05-2008, 05:19 PM
  #4209
Banzai2.4's Avatar
no
full spool by 3500-4000 RPM...
Old 08-05-2008, 05:24 PM
  #4210
DoubleLP's Avatar
NICE Travis!
Old 08-05-2008, 05:26 PM
  #4211
Banzai2.4's Avatar
ye man, im jus waiting for the guy to come on so i can pay him!!
Old 08-05-2008, 05:28 PM
  #4212
DoubleLP's Avatar
You can give me the money if you want.
You can trust me.
  #4213
Banzai2.4's Avatar
haha nah :P
Old 08-05-2008, 10:03 PM
  #4214
tkaugh29's Avatar
no
im no turbo expert by any means but isnt that considered alott of lag?
Old 08-06-2008, 12:28 AM
  #4215
Banzai2.4's Avatar
no travis...
FULLL spool by 3500
itll spool before that.. i jus hit PEAK boost at 3500RPM
Old 08-06-2008, 01:29 AM
  #4216
cruisn's Avatar
I used to get full spool at 2500 rpm at 14psiin my daytona... then I puton a 60 series.... 4000rpm and your jsut touching peak...with only a 6k redline to work with
Old 08-06-2008, 10:39 AM
  #4217
sidejam's Avatar
Lag is more the transition from when the turbo starts to provide power. If you have a low compression engine that runs about 15 psi or so and has full boost by 3500 rpm, you'll notice a lot of lag. However, if you have a high compression engine, running about 8 psi with full boost by 3500 rpm, the lag will be a lot less noticeable. It's not so much when the boost adds power, but, how much power it will add compared to the power while out of boost.
With the LE5 having a compression ratio of 10.4:1 and not being designed for boost, I suspect you won't be able to safely run much more than 8 psi on pump gas. So... with a high compression ratio, and low boost, there won't be much boost lag in this application.
In order to run more boost, the compression ratio would have to be lowered and at that point, power out of boost will be less. In this scenario, with a compression ratio of around 9:1 (just to put in a number) and running about 15 psi, if full boost was achieved by 3500 rpm, boost lag would be noticeable.
So, boost lag is not just where the turbo spools in the rpm, but the rate of change in acceleration over a period of time. Having a turbo that is too big is just about as useful as having a turbo that is too small. The turbo has to be properly matched to the engine.
Just my opinion for whatever it's worth!
Old 08-06-2008, 10:59 AM
  #4218
Banzai2.4's Avatar
haha thanks for the lesson in turbos ed
there are a few cobalts using the 16g turbo, and it matches the engine pretty well from what ive read..
Old 08-06-2008, 11:51 AM
  #4219
sidejam's Avatar
Personally, I think that is a good choice in turbo's. Not sure how'd you tune it. But, I suspect that with a decent tune at 8 psi, your car should be able to run very low 14's or maybe even high 13's. What size intercooler pipes are you going with and how big of an intercooler will you have? Even just going with pipes that are too big or an oversized intercooler can cause lag. I can't remember the exact air speed you want through the intercooler pipes, but there is a calculations based on CFM and air speed to determine the best intercooler pipe size. If you have a massive intercooler, and 3" pipes, that poor turbo has to fill everything before you achieve boost. That alone can create lag.
Keep in mind the Talon's and Eclipse's that ran the 16g were only a 2.0L. A lot of those guys even went to the 20g turbo!
If you haven't read Corky Bell's "Maximum Boost" you really, really should. That will answer all your turbo questions.
Old 08-06-2008, 04:58 PM
  #4220
1WhiteSSTC's Avatar
Who's goin to race city on friday? Better yet, who is going to race city and is willing to brave the auto-x course muahahaha.
Old 08-06-2008, 06:14 PM
  #4221
tkaugh29's Avatar
i dont think anyone on here does autoX. is secret street gonna be open friday? i know vans warptour is here right now. but i donno how long its stays.
Old 08-06-2008, 07:03 PM
  #4222
1WhiteSSTC's Avatar
there isn't anything posted on race city's website atm but I am hoping tomorrow they will have it updated for this weekend.
Old 08-06-2008, 07:07 PM
  #4223
cruisn's Avatar
you have an auto -x course?? where and when??
Old 08-06-2008, 07:17 PM
  #4224
1WhiteSSTC's Avatar
every friday night at secret street at race city speedway in Calgary, you are more than welcome to check it out, it's TONS of fun and sry just does NOT compare to the pathedic 1/4mile......I just wish they had longer courses around here. Even if your new to auto-x or don't know the course that well you will still have fun. My first night i out I was running too low of PSI and ended up taking out alot of cones cause I didn't know the course but I still had more fun than ever b4. Swaybars and aggresive alignments are your best friends in auto-x, support that with wider aggresive tires and proper PSI and you'll be flyin thru the course
Old 08-06-2008, 09:54 PM
  #4225
bigrroberto's Avatar
NICE TRAVIS!!!
That's pimp. You MIGHT be able to pick up some chicks with that things now
Oh and you better still be coming to Castrol on Friday. I wanna see you race Mat and put him in is place
Quick Reply: Calgary - random talk thread
