Calgary - random talk thread
#4527
ya tomorrow i'm gonna tighten everything on the intake and exhaust (namely the manifold bolts) and check for any vacuum leaks. this is just pissin me off simply because the damn thing misfires on all 4 cylinders according to the tech 2 but i don't feel any misfires.
#4539
And I haven't put it back to stock yet... Anyone knows of a stock m62 for sale, let me know.
#4540
update guys. so i pulled my intake manifold off and found there was a bunch of oil in the manifold its self as well as a little bit in the intake tubing. so i did the fix for the pcv orifice, put it all back together. so far the maf seems to be reading where it should again, the LTFT's are around 6 in cell 17, no misfires and no knock. so we will see what happens in the coming hours. hopefully my luck will turn around now
#4541
you gotta have patients with cars. Every brand has a problem. Not to mention the minute you start modding it theres always a higher risk of you running into an issue.
#4544
this is the first issue i've really had since i got it and that was almost a year and a half ago. i had one little random misfire but that cleared up with a fuel line cleaner
#4547
dude how do you afford 1800$ car payments + insurance while going to school? i want that job! or do you got someone helping you with payments?
#4548
used the acdelco fuel line cleaner. the stuff you just put in your gas tank.
so no cel but i have noticed that i have a weird idle now, almost like its misfiring but i checked all that before i left the shop. but given the amount of oil that was getting into my intake i wouldn't doubt that thats what is causing all of this. so i'll be checking it out tomorrow. that and getting an oil catch can and new silicon couplers for my intake.
#4549
#4550
so far no more cel thankfully. and i've done some redline shifts through 3 gears and still nothing. but when i scanned it, it was still running pretty lean, sprayed some throttle body and intake cleaner in the system and it went back down to normal so we will see how she goes. oh and after the throttle body cleaner it seemed to idle better.
