Calgary - random talk thread
Damn. I also could have given you the muffler section plus tip. But mine too went into the garbage
just letting you guys know that me, kass and a few friends are going camping at the end of the month and anyone that wants to join is welcome to join us for the good times.
Firstly, the car is OMG orange and stands out a lot more; and I like the flexibility of being able to switch between the two. It's just temporary until I decide if I want to find a wingless trunk or get a Tjin one.
For Sale 2006 Cobalt SS/SC 87,000km 12500. Fully built tvs cobalt
For sale is a modified cobalt I had a kid and need something different. It is a fun car to drive and more potential to make more power.
Following work has been done
Built motor( about 5000km ago)- motor did not blow up, rebuilt to handle more power.
Diamond pistons and total seal rings- Ceramic and Teflon coated pistons
Supertech stainless steel valves
ZZP 78lb valve springs
ZZP 4340 connecting rods
Ported Head
cometic head gasket
arp head studs
TVS Supercharger 1.3 L vs stock 1.0L-comes with 2.7/2.9/3.1 pulley
3 inch intake
Throttle body spacer plate with two pre drilled holes
Snow performance methanol injection kit
ZZP BFRS ( return fuel system)
Dual pass endplate
Additional heat exchanger for cooling of intake charge
Spec 3+ clutch
Upgraded Axles
Header with 3 inch exhaust
WOT box with launch control
Traction bars- not on car or installed yet
Aftermarket Rotated transmission mount(TTR)
Aftermarket engine mount (TTR)
LC-1 wideband
Mechanical boost gauge
Interceptor scan gauge
Oil pressure gauge
EGT gauge- needs a new sensor cable
Pedders coil-overs
Aftermarket rims with bf Goodrich kdw tires 90+% tread left
Rear sway bar- turbo tech racing
Front strut bar zzp performance
Vis carbon fiber hood
Carbon fiber wing insert
Slotted rotors all around with hawk brake pads
Aftermarket shift boot and e brake cover
Jvc head unit (dvd) comes with xm radio hook-ups
Alpine amp and two type e subs
Tuning software is also available for purchase for extra money
probably missing things as well but this is majority of it
__________________
Ported Head
cometic head gasket
arp head studs
3 inch intake
Dual pass endplate
Spec 3+ clutch
Upgraded Axles
LC-1 wideband
Oil pressure gauge
Pedders coil-overs
__________________
what - you're on FB an not in the "group"!??!?
I don't think I ever asked your last name (not that I really know how to do much on FB anyway)
GM Tuners of Calgary
never was a fan of plastic dip... lol some must learn the hard way....
i hope that car goes to good person tjay.... i know i will be sad if it falls in the wrong hands......
FOR THOSE WHO NEED TO TUNE ON DYNO. SAMMY TOOK THE CAP OFF!!!!!!
for those who are interested please contact me....
