Calgary - random talk thread
Old 07-05-2011, 05:07 PM
  #19326
Acey's Avatar
^^did you do something about that rear bumper filler piece?
Secured it so at least that won't get worse, but there's a million other things on the paint I need to fix/get fixed before I tackle the lip.
Old 07-05-2011, 05:16 PM
  #19327
soundjunky's Avatar
Originally Posted by Projekt
What do you have?
top of the last page.
Old 07-05-2011, 05:20 PM
  #19328
Projekt's Avatar
PM me a price on the Pedder coil overs, Tuning software and the Tires off of the rims if your willing to let go of them
Also the Wing insert is just the center section of the high rise correct?
Old 07-05-2011, 08:16 PM
  #19329
cli3e0339384398jk's Avatar
pm'd you
Old 07-05-2011, 08:20 PM
  #19330
jrmotosports 88's Avatar
honestly tjay is it worth parting out.... hell i think your low on the price
i give you 15 if i could.... this is so depressing..........
Old 07-05-2011, 08:21 PM
  #19331
here is what im thinking for prices if i part out- All would be without shipping, the prices are very fare
TVS Supercharge comes with 2.7/2.9/3.1 pulley 1200
3 inch intake 75
60lb injectors with harness 100
Throttle body spacer plate with two pre drilled holes 30
Snow performance methanol injection kit 125
ZZP BFRS ( return fuel system) 125
Dual pass endplate(need your stock one) 50
Additional heat exchanger for cooling of intake charge 50
Upgraded Axles (need you stock ones) 50
Header with 3 inch exhaust 0
WOT box with launch control 125
Traction bars- not on car or installed yet 50
Aftermarket Rotated transmission mount(TTR) 100
Aftermarket engine mount (TTR) 50
LC-1 wideband 125
Mechanical boost gauge 30
Interceptor scan gauge 150
Oil pressure gauge 30
EGT gauge- needs a new sensor cable 0
Pedders coil-overs 800
Aftermarket rims with bf Goodrich kdw tires 90+% tread left(need your rims and tires) 300
Rear sway bar- turbo tech racing 75
Front strut bar zzp performance 60
Vis carbon fiber hood 300
Carbon fiber wing insert 100
Slotted rotors all around with hawk brake pads 0
Aftermarket shift boot and e brake cover 25
Jvc head unit (dvd) comes with xm radio hook-ups 200
Alpine amp and two type e subs 100
Old 07-05-2011, 08:22 PM
  #19332
its not but i doubt anybody will buy this heavily of a modded car
Old 07-05-2011, 08:27 PM
  #19333
i say its so depressing, you cant change my mind bud..... i damn near give my nuts for that car.......
Old 07-05-2011, 09:35 PM
  #19334
thedude411's Avatar
omfg i want the tvs or the coilovers. but i wont be to afford them this month since i just got my kayak... fuckkkkkkkk i wish i would have held off on that purchase right now. actually! i get the money from my house later this week... so i might have some cash
i would be willing to swap axles and buy the dual pass off you regardless tho. but we would have to swap them in your garage or something
Old 07-05-2011, 11:27 PM
  #19335
Sylver01's Avatar
Found out that my car weights 3000 lbs with just over a half a tank of gas in it! Lol
And tjay, that sucks. Hope you get what you want out of everything
Old 07-05-2011, 11:34 PM
  #19336
outtamymind's Avatar
What's the results jon?
Old 07-06-2011, 03:41 AM
  #19337
kasper_17's Avatar
I'm always game for meeting up...
There's a car show going on saturday that I'll be in;
Show 'n Shine
you puttin the cobalt in? or somethin else and is there a bunch of ppl goin? if so maybe i'll register
Old 07-06-2011, 04:27 AM
  #19338
kasper_17's Avatar
Gave her a nice cleaning yesterday... dam i hate the cotton flying around
Old 07-06-2011, 08:43 AM
  #19339
Sylver01's Avatar
The result of what steve?
Looks good Kasper! Love your choice in color! Lol
Old 07-06-2011, 11:15 AM
  #19340
soundjunky's Avatar
I plan on bringing the Grand Am to the show... it's more of a "WTF ~ why did soemoen bring this car?" type deal.
besides yesterday my car kinda decided to try to hump a curb... I cleaned it up, but still...
Old 07-06-2011, 11:16 AM
  #19341
Projekt's Avatar
What aftermarket rims do you have bluecobalt?
Old 07-06-2011, 11:20 AM
  #19342
Projekt's Avatar
Also Jon. Your a pretty smart guy. Where is that thread for the rear brake problem on ss/tc's i have to take my car in for that soon (or replace the rotors). Busy at work or else i'd find it myself.
maybe you can give me some insight.
Old 07-06-2011, 11:30 AM
  #19343
slider pins seize due to lack of lubrication causing inner pad to rub on the rotor causing premature wear of the rotor and pad.
most cases lubricating the slider pins as part of the regular maintenance will help with this situation but is not always a garaunteed fix. Many dealers replace the rear calipers
Old 07-06-2011, 11:31 AM
  #19344
DiabeticKripple's Avatar
i lubed mine when i did my front brakes. debating on whether i should do the back brakes
Old 07-06-2011, 11:34 AM
  #19345
jordan with ours its not an issue as ours are sealed with a boot and do not lose the lubrication as quickly. where the SS/TC's have an open slider pin design due to the brembo setup and lose the lubrication much quicker
Old 07-06-2011, 11:39 AM
  #19346
Projekt's Avatar
So Steve, as a GM mechanic what do you advise i should do in this case?
Old 07-06-2011, 11:42 AM
  #19347
is the car still under warranty? and i don't work for GM anymore, haven't for a few years now
Old 07-06-2011, 11:46 AM
  #19348
Projekt's Avatar
It is. Or at least should be.
Old 07-06-2011, 11:51 AM
  #19349
then let them worry about it this time. and when you do your oil changes just remember to lubricate the rear sliders after that
Old 07-06-2011, 12:00 PM
  #19350
Projekt's Avatar
Okay. Thanks
Quick Reply: Calgary - random talk thread
