Snakes TVS Build
Snakes TVS Build
I made another post in the 2.0L section but id rather have one here so im deleting that one. Easier to update and maintain one here.
So on with the build info. As most of you know i have a 2007 SS/SC. My mods currently are:
2.8" ZZP Pulley
60lb Injectors
2 Step Colder Spark Plugs
Injen 2.5" Cold Air Intake
Devils Own Meth Kit, 50/50 mix, 3gph nozzle
Cobalt Addiction Heat Exchanger
Custom tune (pretty much a base tune)
Ingalls Torque Damper
Wingless
5% tint in the back 3 windows
Tinted taillights
AEM Wideband Gauge, Volt Gauge and stock boost gauge
Eibach Sportline Lowering Springs
Gen 1 Halo Lights
8000K HID's
"Cobalt SS" Spark Plug Cover
"Supercharger" Fuel Rail Cover
"Cobalt SS" Door Sills
Custom Dash Trim
Chromed Rad Hose
"SS" Underhood Cover
So those are the current mods...here are the mods that are on the way.
Harrop TVS-LSJ1320 Supercharger
SS/TC 30PSI Boost Gauge
TTR Solid Engine Mount
OTTP Rotated Tranny Mounts - Stage 2
CIA Header
CIA 3" downpipe with hi-flow cat
CIA 3" Catback Exhaust System
Mods to come later on is all engine internals, LS4 Throttle Body, 3" Intake, smaller pulley, 79lb injectors, return fuel style system
So here are some pics of how the car is coming along...
The car completely stock...
M62 taken out
Yes there is a flashlight holding the belt from falling...
2.8/60/wideband
Heat Exchanger
Meth Kit
Hood Up
Tail Lights
Torque Damper
And Some Videos...
And hell one more pic of the balts first time in the winter...
2.8" ZZP Pulley
60lb Injectors
Wingless
Tinted taillights
Gen 1 Halo Lights
8000K HID's
Custom Dash Trim
Chromed Rad Hose
CIA Header
M62 taken out
2.8/60/wideband
Heat Exchanger
Meth Kit
Hood Up
Tail Lights
Torque Damper
And Some Videos...
everything should be in except for the header/dp and exhaust...those will probably arrive the week after the meet iiunno. I just checked the tracking status, TVS arrived in edmonton at 3:40am this morning so it should be out for delivery today. The engine mount should be here also. The rotated mounts should have shipped yesterday or today (josh called me and said they had no upper mounts so he had to wait to get it in before he could ship them) The boost gauge i already have. The header is made, the exhaust is half made (CIA just needs the resinator and exhaust tip) and they r waiting for parts for the downpipe. Thet said they might get it shipped this friday or monday.
Today i have to do my out of province inspection so i had to cut the HID's out of my wiring harness and put the wiring harness back into the stock headlights, also had to strip the tint off my tail lights. So today after the inspection i need to re-wire the HID's...get my Gen 1's re-installed into the car. Re-tint my tail lights (might debadge the trunk...havent decided) Then im taking the car to get the 2 front windows tinted.
Ok so unfortunely the post office people are retards and didnt deliver my TVS today, They said it should be here tomorrow but im Duty Driver at the base so i have to work at 8am and i dont come home until Saturday morning. Anyways today i got the M62 out...accdently somewhat broke the fuel rail. Its not broken but a piece came off that shouldnt have. Fuel rail is fixed tho. Couple people were saying i should get the dual pass to keep the heat down but i dont want to get that right now so i decided not to go with the 5gph nozzle for meth and just go to 7gph. Boy was that a bitch to get that nozzle in my intake. Also my boost gauge came in the other day. Having a small issue with it though. On the m62 i was hitting 130kpa (18psi)...this one is a SS/TC gauge (30psi)...and it says im hitting 25psi...so i somehow gotta recalberate it.
So heres a few pics of whats done so far.
This is the new boost gauge, thinking it should read 0psi when its not installed?
2.8 Pulley
M62
Exhaust manifold gasket and downpipe to exhaust gasket
the maf sensor, had to dremel it down so the TVS will fit. Picture makes it look like a shitty job but its not as bad as it looks
2.8 Pulley
M62
check out the pic of the boost gauge here its the same as yours
aslo im pretty sure you need the TC boost sensor to make that gauge work right
http://www.crateenginedepot.com/stor...P2291C212.aspx
isnt it the same gauge as yours jody or is yours kpa? And Silver Bullet, thats where i got it from. Will the turbo charge sensor work on the supercharger? Got the idea of swappin gauges from Wicked...he was one of the first guys to get the TVS and he made a FAQ page and stated that u will need a TC gauge...but no one else seems to be having this issue.
it should work on the sc its out of wack cause the 20 and 30 psi gauges have the same range of sweep so thats why u need the other sending unit thats matched to the 30 psi gauge
M62 and the TVS
Pulley Difference...holy hell is the TVS pulley light as a feather!
Harrop!
Inside
Inside again
well that wont be for awhile...****** banjo bolt to the coolant line broke....again!. Last time it broke durin the install of stage 2. James tried to get one but they had none around so he actualy made one....snapped in half again so im trying to find one in edmonton, theres a place here that might have one but they arent open until monday
Anyways heres the progess i got done so far...almost done but i dont know if i can finish it today.
TVS just bolted in the car. (2 lower bolts were a bitch to tighten)
Belt was a bitch to get on cuz the 15mm part for the tentioner is stripped...but i took a tire iron, pushed the tentioner down and then stuck a 14mm socket between the tentioner and part above it to keep it down while i get the belt on...worked pretty good.
Almost everything hooked up
But then this happends....went to canadian tire bought a 14mm bolt and im going to drill the holes in it...thats what james did so hopefully i can do it.
thats what a couple people told me but TTR and OTTP said it would be fine, TTR said they only like 1 person have issues with both in at the same time but many others didnt have a single problem. I'll find out when the time comes, just trying to drill holes in a bolt to make it a banjo bolt...was going good but now i snapped the drill bit in the hole so i have to start over on a new bolt. If i can solve this problem today then ill defently have the car running, wont be really driveable without the tune but that will come next week
well i thought i fixed the fuel rail but i guess i didnt, started the car up and gas shot all over the place..going to be a couple weeks until i can get a new one...guess u can scratch me off the list for the meet. I still wanna go so i might show up with my bike
checked all the dealers and wreckers? in edm and calgary and red deer? some one must have a new fuel rail and that bolt. of all the cars comin to the meet, yours and matts were the ones i was most interested to see. there must be a part somewhere in this province. being you guys are in deadmonton and i'm in cowtown those two cars are the ones i want to see for sure man!!!!!!!!!!!!!!
yea monday im going to check out a few salvage yards to see if i can get a fuel rail off a cobalt or a ion...they both have the same fuel rail. Also if i can find a wrecked cobalt im pretty sure i can get a banjo bolt. Tried to make one today...was almost done and the drill bit snapped and got stuck in the hole...i was pissed because i did a really good job for making a banjo bolt out of a actualy 3/8 X 1 1/2 bolt...lol. But yea. Tomorrow im going to install the engine mount and put my tail lights back on (had to tint them again after the inspection, came out pretty good except for the little pieces of crap that got stuck to it...but either way its good.
On the plus side. UPS claims my rotated mounts will be here on the 16th so hopefully i can get the car into a shop to get them installed to get me better times on the track (if the car is ready) If its not and its ok with chad and everyone else im bringing my bike and going to race the bike for the first time. But i really hope the car is ready.
