Snakes TVS Build
#81
unless u really need the power gain...dont get it. If it wasnt for the fact i had so much back presure and loosing alot of hp cuz of the restriction i would have stayed stock. Thing is way to loud. iiunno about everyone else but hate all types of exhaust on cobalts or any 4 banger. thing is so loud and i feel like a retard. I was always saying "oh look at the retard with a loud exhaust...waste of money to make yourself sound like pos." And now i feel like a pos cuz of the sound....but when i step on the gas and get the power...it makes me feel better. lol
#87
Your tune is for stock exhaust.
You've opened it up a TON.
I'm sure your trims are probably out and you've likely moved to different areas of your fuel/timing maps.
That's sure to throw your mileage off
#88
Guess I was right.
#91
well i have to pm steve but im going to CFB Suffield (army base in canada) from the 11th to the 19th of Aug to fire off some TOW missles on the LAV-III. So probably when i come home from that.
#92
Small update. Steve adjusted my tune again. The trim was at 25% so i was using alot of fuel..lol. We put my afr back to 11.9. Added 1* of timing so im at 25* of timing...no knock. After 3 or 4 pulls on the highway the highest we seen the iat2 get to was 149*...also it was 27*C outside so that played abit in the temp. He also found a issue from my old tune. Idle issue is fixed. Also changed the amount of boost in 1st gear. From idle to 4000rpm its 75% and then works it way up from there, at 5000rpm its at 100% boost. Did a pull from like 5kmh...tires didnt break loose at 60% throttle. Did another one and it broke loose at 68% throttle. Car feels alot better now. Thanks again steve! Cant wait to dyno and go back to the track.
#95
Before i put the tvs on i ran a 14.4@106 with my m62 - 2.8", 60lb injectors, meth, h/e and cai...had a completly fucked up tune with that. I have to learn all over how the car launches now at the track but if i can get my 60' down low i should be able to get to 12.9 or 13.2 ET @ 110-111mph
#100
yea thats what i heard .5 or if u r good 1.0 with slicks. When i come back from the field with the army and i get to the track, depending how many passes i get that night iiunno what i will make for time. Like i said the car launches alot different now. So i have to learn how to launch it all over again. Letting the clutch out is the same but the amount of gas is ALOT different. When i was at the strip on friday i would stage at 2000...ease the clutch out, once fully out i would floor it and not spin....remember i was only at 40% boost in 1st. Now today when i did a few pulls while we were tuning we turned the boost to 75% and at 4000rpm it starts to climb...by 5000rpm its at 100%. I did a launch on the highway was only at 60% throttle...tires didnt break loose and the amount of power felt exactly as i did at the track when i floored it. Then i tried again...computer said i was at 68% throttle and tires broke loose.
