For Sale 09 Track Setup Cobalt SS, sedan
Been a long time CSS. It's time to move on for me. I see lots of for sale posts. I wish the best of luck to all of them. Myself included
Heavily modified, well balanced car. Fun and reasonably tame on the street and fast on track. Always well maintained.
pics and vids:
09 Chevy Cobalt SS, $10,000
Suspension/brakes:
Engine:
Interior:
Exterior:
Also available:
pics and vids:
- https://www.flickr.com/photos/wangsp...57622703093383
- https://www.flickr.com/photos/wangsp...57632133096040
- Sedan
- 52,603 miles
- Sunroof
- Limited slip differential
Suspension/brakes:
- Powell Motorsports
- Triple X 1.5" rear swaybar
- Leading control arm bushings
- Trailing control arm bushings
- Sealed spherical bearings
- Twisting rear beam spherical bearing kit
- Original YYZ v1 springs (the first set! custom coated)
- Custom subframe connectors, bonded and bolted in, with jacking points
- Koni yellow front inserts, rear shocks (rears are new)
- Custom steering rack spacers to remove bumpsteer
- New factory Brembo front calipers
- Stainless steel front brake lines
Engine:
- Custom tune by me, track safe
- 300-310 whp
- I tuned someone that dynoed 320 hp / 380 ftlb, mine is more conservative
- Powell Motorsports/OTTP front rotated transmission mount
- 4.05 Final drive transmission from HHR SS (31K miles)
- New: Axle seals, throw out bearing, clutch pipe and elbow
- KY stage 2/3 clutch (custom combo)
- K&N intake
- Hahn catback exhaust
- ZZP short intercooler (does not hang low)
- ZZP upper intercooler pipe
- Forge bypass valve
- Fumoto oil drain valve
- Moroso air/oil separator
Interior:
- TWM shifter with custom taller Delrin shift knob
- Redline Goods leather shifter and brake boots
- SRP aluminum pedals
- Sunroof dome light
- This normally is only available on non-sunroof cars
- Infinity front speakers (also 2 ohms, like stock) installed in stock positions
Exterior:
- Powell Motorsports tow hooks
- Retrofit Source bixenon FXR headlights
- Enkei PF01 18x8
Also available:
- Catless downpipe (ZZP I think)
- Depo headlights
- Raybestos ST43 front pads
- Titanium backing plates for front calipers
- Extra set of 18x8 Enkei PF01 with Nitto NT01 in 235/40-18
Dutchman (01-04-2020)
It actually rides quite well. The YYZ v1 springs have lots of travel available, so it's rare that they bottom out, which is what really hurts. It rides better than any Cobalt coilover kits will ever ride. You can see from the pics that the car isn't really much lower than stock.
For me, I choose function over form.
