For Sale 2006 Cobalt SS/SC G85 Coupe $4600 USD/$6500 CAD obo
Located just outside Vancouver BC - Can meet at the border for a viewing.
145miles/233km
Compression test results 70-75psi per cylinder
G85 Package with Recaro Seats & Limited Slip Differential
Lowered 1.5" from stock SS (have original springs)
Eaton Supercharger w Stock Pulley
Injen Cold Air Intake w K&N Filter
MadFab Header Exhaust Manifold
ZZP 2.5" Downpipe & Cat
Ingalls Torque Damper
Auto Meter Boost Gauge
Tuned with HP Tuners - Can detune for mild driving if needed.
Debadged and De-Winged
18" Chevrolet Alloy Wheels - Powdercoated Gloss Black
Dunlop 18" Tires with 60% tread
Pioneer AVH-X3500BHS with full video & bluetooth all hooked up
Recent Work Done:
Royal Purple used for every oil change since 47k
Supercharger Rebuilt with new ZZP coupling
New Pads & Rotors
New Red River ZZP Clutch
ZZP 2.5" Downpipe/Cat & Madfab Header installed
Front Wheel Bearings installed
Moog Swaybar Endlinks Installed
Solid Shifter Mounts & LNF Solid Shift Cable Mounts
Stainless Steel Braided Clutch Housing
New MAP Sensor & MAF Sensor
Rear Wheel Bearings Installed
Timing Chain & Gears
WaterPump Chain & Balance Shaft Gears
New Battery
Full New Fuel Line & Fuel Filter Installed
The Bad:
A/C Compressor is bad (no A/C)- But have a spare to throw in
Drivers side tweeter is crackling
Key Fob's are old and stopped working. $50 fix.
Spares (I have a big rubbermaid tub to go with it):
LS4 75mm Throttle body/Spacer & Tapered intake
Spare Passenger Side Fender
Spare Set of Side Skirts
Radiator/Heat Exchanger
Fuse Panel
Water Pump
Stock Airbox
Stock Springs
Also have a spare set of 17" OZ Racing SuperTurismo GT wheels with Nitto NT-01 track tires that are also for sale and negotiable - 5 x 100 fit on Cobalts.
