For Sale 2006 lsj
Old 01-29-2016 | 01:06 PM
valencia1900's Avatar
It has come time for me to part with my cobalt as school is killing me and my right knee is just plain hurts, so I have to drive an automatic until I fully recover if not, surgery.
So I am selling my 2006 LSJ, it is a G85 with lots of upgrades and is located in So Cal in LA/Orange County. I am not in a hurry to sell and will get the smog check, I will give further details on that via messages.
Pros.
60 pound injectors and harness
GMPP Clutch and new flywheel 7k miles ago
3inch zzp intake
3inch zzp headers with catted dp going into a 2.5 inch magnaflow exhaust.
monroe struts on eibach pro springs
zzp lower control arms
adjustable end links
steel brakelines
hawk hps pads have 10k miles on them
zzp slotted and drilled rotor
eibach front and rear sway bars
New Fuel Pump and filter 7k miles ago, changed due to a leak
Hurst shifter
Billet alluminum shifter clamp- the stock one broke and I replaced it
zzp upper and rotated transmission mounts
Still has the recaros, they are dirty since I do not know how to clean them
dual pass end plate with option A
Zzp stealth heat exchanger
HPS radiator hoses
Recent fluid change done on the transmission 7k miles ago
Is riding on enkie M5s and Bridgestone S-04s
Stage 2 with a 3.1 pulley ZZP
Stage 1 axles ZZP
Cons
Condenser is bent from previous owner
Has primer on the drivers side from previous owner
some curb rash on 2 of the enkies
Passenger side spindle has play by the ball joint, the ball joint was replaced as the suspect part, but it was the spindle causing the play.
The car will come with a 2nd set of OEM wheels and extra parts, what I can find in my garage, which should be parts for an option B(probably not complete), aem intake, springs.
If you are interested send a message.
Price is 5,000 or best offer
current miles are 152311 but will go up very slowly.
Old 01-29-2016 | 01:59 PM
jcobaltss's Avatar
BTW tuff stuff will clean the seats. It's like 3 bucks at Walmart
valencia1900 (01-29-2016)
Old 01-30-2016 | 10:31 PM
Sean Cummings's Avatar
nice upgrades. Good luck on your sale
Old 01-31-2016 | 11:14 AM
Thanks, all I did was replace broken parts
Old 02-08-2016 | 03:14 PM
Bump, I need, to get rid of it, can do 4000 with the stock wheels, then I will sell the m5s seperate
Old 03-22-2016 | 01:27 AM
Car has been sold
scagnetti76
12-24-2015 03:57 AM
izcain
12-21-2015 01:33 AM
12-15-2015 11:21 PM
spaceagejuliet
12-02-2015 05:16 PM
riceburner
12-01-2015 11:12 PM
Quick Reply: For Sale 2006 lsj
