For Sale Fully Built Arrival Blue 06 Cobalt SS
Chris Broeders
Schaumburg, IL
Cougar66_05@yahoo.com
Well after going back and forth the last few weeks I've decided to my baby up for sale. I've just come to a point in my life where my priorities are changing. As much as I love the car there are many other things I'd like to do and by selling my car it would make it easier. I actually just got her put back together a couple months ago so a majority of the parts are basically still new. I have all the reciepts and paperwork to go with the car. It's currently on a 20 psi tune and has not been dynoed or brought to the track yet. I have more invested in parts alone than I'm asking for the car, sois great for someone looking to have a great fully modded car but not have to deal with the hassle or huge bill. Engine, turbo, frt spindles,tires, lower ball joints, clutch master cylinder, H&Rs and endlinks have a little under 2000 miles on them and transmission, struts and shocks have a little under 10,000 miles on it. Chassis itself has aprox 75,000 miles on it. I also have original black and blue leather frt seats if buyer prefers over the TC seats.
Asking Price is $16,000 OBO
Engine:
Darton Sleeved Block
Custom Je Forged Pistons
Pauter connecting rods
Balanced up to 10,000 RPM rotating assembly
Vented valve cover
Ported and polished Head
Supertech Valve springs
272 Cams
GM Racing adjustable cam gears
balance shaft delete
Level Zero Motorsports balance shaft delete bushings
ATP oil catch can
AEM Dry flow filter
Custom aluminum charge pipes
A/c Delete with shorter Gm Non A/c belt
All new GM gaskets, Bearings ,etc.
80 lb injectors
All machine work done by Opel Engineering
Turbo
Precision 5857 PTE Turbo
One off sheetmetal intake manifold with velociy stacks
Pwerks turbo oil line kit
Custom stainless down pipe
ZZP turbo manifold
Tial 38mm Wastegate
Tial Q Blowoff Valve
CX Racing Intercooler
Hallman Pro MBC
ATP Stainless teflon return line
Trans
LNF Trans W/LSD
Exedy Hypersingle cutch and flywheel
LNF Axles
LNF throwout bearing
new clutch tube
powell stg 2 rotated trans mounts
TWM short throw shifter with base bushings
H&R Springs
Powell TCABs
Moog lower ball joints
Moog sway bar endlinks
LNF Frt spindles
Wheel conversion to 5x114.3
Slotted and drilled rotors redrilled for 5x114.3
17x7.5 Motegi Racing Tracklite 1.0 rims (~14.08 lbs)
235/40/17 Dunlop Direzza Star Specs
Blox Racing Lug nuts
Gauges
Cobalt series mechanical boost gauge
Cobalt series mechanical oil pressure gauge
AEM UEGO wideband
Aeroforce interceptor scan gauge
Interior
Black TC SS Seats
Pioneer AVIC F900BT Head unit
Blue painted dash trim
"Brick" eBrake cover removed and leather boot installed
Black HVAC contol unit
ZZP tripple gauge pillar
Visual
MRZ fuse box cover
MRZ coilpack cover
All MRZ caps( oil, brake, washer fluid, strut)
LED Tail lights
5% tint on rear windows
Black painted stock headlight housings and painted eyelids inside lenses
Last pic is with old temporary upper charge pipe, just realized I don't have a pic with the new pip yet. I'll upload more pics when I get a chance.
Schaumburg, IL
Engine:
Vented valve cover
272 Cams
ATP oil catch can
AEM Dry flow filter
80 lb injectors
Turbo
ZZP turbo manifold
Tial 38mm Wastegate
Hallman Pro MBC
Trans
LNF Trans W/LSD
LNF Axles
new clutch tube
H&R Springs
Powell TCABs
LNF Frt spindles
Gauges
AEM UEGO wideband
Interior
Black TC SS Seats
Visual
MRZ fuse box cover
MRZ coilpack cover
LED Tail lights
yeah they're tinted blue, it's actually over reduced color of te car so it matches perfectly and with the taillights being LED it shines through red just like normal, altough reverse lights to glow blue though lol
LOL thanks, I almost went with brembos but decided not to so I could run a decent slick if I wanted to. I wanted to go with more function with the wheels, can't really argue with 14 lb rims
