Crate Engine Depot Crate Engine Depot is a proud Supporting Vendor
Stage 3 Posted up on CED site
Old 12-18-2006, 02:41 PM
arsenal21's Avatar
So I would need to buy stage 2, stage 3, an exhaust, neutral balance shafts, high speed valve springs, and nitrous to reach the full potential of stage 3....
Old 12-18-2006, 02:45 PM
distillion's Avatar
also the surge tank and 15 psi cap, plus all the fittings, hoses, clamps ect that does not come with this kit.
Old 12-18-2006, 02:47 PM
360 L337 User
R33P3R007's Avatar
Originally Posted by johnkb8
cool details for the install...
http://www.crateenginedepot.com/pdfs/s3ins.pdf
EVERYONE READ THIS!!!!
your all asking questions that are explained here.
Old 12-18-2006, 02:48 PM
arsenal21's Avatar
so does it disable the A/C????? I read it.
So what kinda damage am I looking at here $2,500 for everything to do this right.
Old 12-18-2006, 02:54 PM
AlphaJaguar5's Avatar
umm arent you guys forgeting the there are controls in hptuners to disable your a/c. So all you'd have to do is hook hptuners up to it and enable the a/c again...
Old 12-18-2006, 03:17 PM
glockglade's Avatar
wet or dry shot? and can i run this without swapping pistons? thanks
Old 12-18-2006, 03:26 PM
mastoer's Avatar
i wonder if where ever gonna push the 300hp mark with out nitrous..i kinda disappointed with the kit only being able get to 260hp all motor..but that adjustable revlimit is cool
Old 12-18-2006, 03:31 PM
OniMirage's Avatar
there are plenty of people reaching that number. you just gotta get **** done correctly. it isnt so much money that is holding anyone back. its mostly availability of performance parts
Old 12-18-2006, 05:14 PM
sethallen's Avatar
is that a GM document, or from CED?
this is actually looking kind of interesting. It's growin on me
Old 12-18-2006, 05:50 PM
OniMirage's Avatar
to be honest it isn't a bad setup ... plug the custom computer when your going to the track then unplug it when you get back and keep warrenty ... at least thats the way it should work but whatever. plus when warrenty is gone add some juice to the mix and your over 300hp when you need it
Old 12-18-2006, 08:37 PM
  #36
spaz's Avatar
Canada
Originally Posted by CrateEngineDepot
I have posted up the Stage 3 kits as well as the Stage PCM's
Stage Kit Link Click Here
Details about the kits are found there.
Kits are in stock!!
they could at least include the tee for the dual pass in the kit I just priced one out today and my cost is $1260 Canadian.That is quite a bit for a pulley,Pcm and a dual pass plate.
I am sure a custom tune could do the same.
Old 12-18-2006, 08:48 PM
  #37
CTCOBALTSSS's Avatar
Do you have to run the dual pass if you run this stage 3 pcm?
There isn't something in the software that would make it necessary to run the dual pass right?
Old 12-19-2006, 02:52 AM
  #38
Nukem's Avatar
no but u Why wouldn't u want the dual bypass
Old 12-19-2006, 08:54 AM
  #39
Well because I would rather just buy the PCM for $325.00 and just install a biger heat exchanger. I already have a 2.9" pulley so this tune would be perfect for me. All I need is the PCM. Better than spending over $700.00 for the whole thing when I only need the PCM.
Old 12-19-2006, 09:02 AM
  #40
360 L337 User
R33P3R007's Avatar
What else do you need to install the dual pass?
Old 12-19-2006, 09:07 AM
  #41
You need the plate and eveything in this link.
http://www.crateenginedepot.com/stor..._ID=196&Page=2
Old 12-19-2006, 10:05 AM
  #42
360 L337 User
R33P3R007's Avatar
Intercooler End Plate Seal 12584355
Item #12584355
12584355 2-Pass Intercooler End Plate Seal
MSRP: $44.12 Your Price: $34.78
Intercooler End Plate Seal 12584333
Item #12584333
12584333 2-Pass Intercooler End Plate Seal
MSRP: $26.30 Your Price: $20.15
Cobalt Surge Tank 10368831
Item #10368831
10368831 Surge Tank
MSRP: $65.52 Your Price: $47.69
Cobalt Surge Tank Cap 15# 15075118
Item #15075118
MSRP: $10.32 Your Price: $5.31
Y Connector 84757
Item #84757
Y Connector 84757
MSRP: $9.90 Your Price: $7.25
Anything else?
Where does the Surge tank mount?
Old 12-19-2006, 10:21 AM
  #43
Right here.
Old 12-19-2006, 10:30 AM
  #44
distillion's Avatar
you have to fab up soem brakets for it.
Old 12-19-2006, 04:00 PM
  #45
360 L337 User
R33P3R007's Avatar
that sux, thats where my water/meth kit will go.
Old 12-19-2006, 05:01 PM
  #46
Nukem's Avatar
but still with a big Heat Exchanger and the Dual Pass ur cooling system will work that much better. Still don't see Y u wouldn't want it
Old 12-19-2006, 05:12 PM
  #47
BlackSS/SC's Avatar
Do you think we really need to replace the o-ring seals on the endplate? I was gonna try to reuse mine when I modify my original endplate.
Old 12-19-2006, 05:41 PM
  #48
CobaltSS422's Avatar
I would just to make sure.. they are only 20 and 30 dollars.. u might as well
and as far as switching between HOM and regular mode i think going through the DIC to change it would be a pain in the ass.. I would rather have a seperate controller like the Turbotoys on the SRT-4 that has a specific button for HOM. Unless GM made it where u hit the "i" button or return button a couple times or something
Old 12-19-2006, 07:56 PM
  #49
blackphoenix's Avatar
so with the nitrous.. are the stock plugs good, or do we need to swap those out? so i guess this motor can handle alot more power then most people think... with the 8k redline and the 50 shot.. i'm starting to wonder if the people who have blown up did so because of custom tunes.. by the sounds of this stage 3 pcm.. everything should be tuned just right for the 100 octane and nitrous.. should be able to push over 300hp easliy with that setup.
Old 12-19-2006, 08:17 PM
  #50
NKs07CobaltSS's Avatar
now i don't get the 260hp with 100 octane gas, who is driiving around on 100 octane and if thats all i'm getting is 15 more horsepower. where the heck do you get 100 octane or 93 for that matter they don't sell it around here!
PS Not impressed with stage 3
Quick Reply: Stage 3 Posted up on CED site
