ZFR vs s256 ( 300 ft, 1/8. & 1/4 )?
I know the s256 is capable of supporting more HP, but I dont know if I will ever mod it that far. So, here is my question
ZFR + fully bolted + tuned + drag radials+ drag bags + stage 4 clutch ( stock cams staying under 7000 rpm )
V.S.
S256 + fully bolted + tuned + drag radials + drag bags + stage 4 clutch ( stock cams staying under 7000 rpm )
I dont care about HP. I care about real world results. So, between those choices which turbo would win in each category?
300ft, 1/8, and 1/4
I might one day upgrade to a ported head and cams combo, upgraded trans, built motor, but you never know what life is going to bring. And if its worth it to put that much power down on a FWD car, or for the same price as moding a RWD muscle car?
V.S.
300ft, 1/8, and 1/4
You asked about drag racing. I answered the question on drag racing. zfr will prolly make more in the 4-5k range, but your never less than 5k , I launch over 5000 rpms and drop to about 4800 and then am never less than 5500 again.
OK lets take this to the extreme. Why not a s259 or the s262? staying under 7k.
In other words at what point would a big turbo not make as much power under7k?
I don't think the 256 comes with the crazy wheel, 259 and 262 do. As far as borg warner turbos 259 is where I would stop unless you want a crazy hp build. A 6262 is a better option than the 262 because the inducer is a little bigger and the exducer is smaller by a little helping spool a touch. Also the exhaust wheel is smaller on the 6262. Staying under 7k I would stop at a 256 in all honesty. You can prolly make the same power with a bigger turbo or more power but the curve is going to be worse.
drag radial wont hold. you need slick to put your power down even a S256 or zfr.
my friend has a zfr and MT slick and something in 3th gear, tire get hard time
he has a HHR ss. 12,8 111.
Vs a mustang Boss:
Vs a mustang Boss:
Vs a mustang Boss:
Video Link: http://www.youtube.com/watch?v=ygZc6a1DYwc
Vs a mustang Boss:
Sent from my Samsung Galaxy S4 using CobaltSS
