09 no lift shift = broken shift linkage
Old 03-22-2009, 01:52 PM
metroplex's Avatar
You do the same motions with powershifting, I am not sure what is so hard to understand. The fuel/spark stuff is transparent and has no effect on the gearbox/shifter.
Old 03-22-2009, 02:11 PM
Gestapo007's Avatar
what your not getting....is EVERYONE UNDERSTANDS! lol
Its the same motion and same **** as powershifting. My 1st post said that NLS had nothing to do with his shifter link cable breaking, but instead just slamming the shifter around like a cheating *****. shift linkage breaking is due to rough shifting but has nothing to do with weather or not you take your foot of the gas when you shift
Old 03-22-2009, 04:31 PM
metroplex's Avatar
ok, understood!
Old 03-22-2009, 04:41 PM
Stamina's Avatar
It looks like we've got two convos going at once here and everybody is unsync'd.
Topic 1: About shift linkages breaking... What Gestpo007 said... a product of any hard shifting no matter NLS or not. If you're slamming it, you can break it.
Topic 2: About if NLS is hard on your engine. Well, it's not good on your engine/tranny, but maybe not quite as bad as if you were powershifting any other car without the ECU algorithm.
...And yes, you are correct. WOT = Wide Open Throttle. It's anytime you've got your gas pedal floored.
Old 03-22-2009, 05:21 PM
Gestapo007's Avatar
^ well said.
/thread
Old 03-24-2009, 07:44 AM
09turbo's Avatar
haha
but the thing is that if you let out to the clutch too fast and the car is not fully in gear, that could also cause a problem because the gas is pegged to the floor, clutch is out, and your jerking the car in gear.
Old 03-26-2009, 09:25 PM
Dinglefitz's Avatar
WOT? Heee... I prefer WAO shift. Same thing tho. No Lift **** works when I get my **** together. My problem is UN-learning 40 plus years of no-throttle shifts.
The few times I've got it right No Lift Shift is fun as hell. I love that little POP ya get when you shift. My $.02.
Old 03-26-2009, 09:32 PM
09turbo's Avatar
yea i love that pop, haha. maybe a little too much.
specially with my magnaflow
RaginChopsuey
10-27-2015 01:27 PM
dennis69
10-20-2015 04:49 PM
Tupp
09-30-2015 08:18 PM
2009blackSS
09-30-2015 05:57 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: 09 no lift shift = broken shift linkage
