6 speed for us?!?!?!
Old 11-24-2006, 02:36 AM
thedubsack85's Avatar
Originally Posted by R&C_rallySS
Interesting post, but I agree with the price and benefits = bad news. However, imgaine how awesome it would be to say you have a Cobalt SS/SC with a 6-speed tranny getting 28-30mpg all the time =D
im sorry but your all wrong. the saab tranny ends up with way shorter gears. the g85 equipped balts and the comp pak redline have a alittle bit taller 5th gear. good to like 165 ish with a stage tune and the 7k redline. the 6 speed with the same tune would top out at 147. the 6th is even shorter than the stock 5th. sorry to be the bearer of bad news.
Old 12-07-2006, 02:54 AM
atownSS's Avatar
actually you are wrong the 6 speed tranny every gear is taller Below is the specs of each tranny off chevy and saabs website and below that is the calculations of each gear at top rpm, and top gear at several mph
SS Supercharged Gear Ratios
First- 4.05
Second- 2.02
Third gear-1.35
Fourth= 0.98
Fifth- 0.69
Reverse- 3.31
Final drive ratio- 3.94
Case material aluminum
Saab 9-3 Gear Ratios
First 3.77:1
Second 2.04:1
Third 1.37:1
Fourth 1.05:1
Fifth 0.85:1
Sixth 0.71:1
Reverse 3.54:1
Final Drive 3:55:1
Case Material aluminum
Gearbox:- SS supercharged 5 speed
Tire:- Kumo 215/45r18
Top Gear gives 28.040 MPH/1000 RPM and a top speed of 196.283 MPH at 7000 RPM
Engine speeds in top gear:-
30 MPH = 1070 RPM 40 MPH = 1427 RPM 50 MPH = 1783 RPM 60 MPH = 2140 RPM
70 MPH = 2496 RPM 80 MPH = 2853 RPM 90 MPH = 3210 RPM 100 MPH = 3566 RPM
Top Speed in 1 gear = 33.441 MPH
And changes into 2 gear at 3491 RPM dropping 3509 RPM
Top Speed in 2 gear = 67.047 MPH
And changes into 3 gear at 4678 RPM dropping 2322 RPM
Top Speed in 3 gear = 100.322 MPH
And changes into 4 gear at 5081 RPM dropping 1919 RPM
Top Speed in 4 gear = 138.199 MPH
And changes into 5 gear at 4929 RPM dropping 2071 RPM
Top Speed in 5 gear = 196.283 MPH
Gearbox:- Saab 6speed
Top Gear gives 30.244 MPH/1000 RPM and a top speed of 211.710 MPH at 7000 RPM
30 MPH = 992 RPM 40 MPH = 1323 RPM 50 MPH = 1653 RPM 60 MPH = 1984 RPM
70 MPH = 2314 RPM 80 MPH = 2645 RPM 90 MPH = 2976 RPM 100 MPH = 3306 RPM
Top Speed in 1 gear = 39.871 MPH
And changes into 2 gear at 3788 RPM dropping 3212 RPM
Top Speed in 2 gear = 73.683 MPH
And changes into 3 gear at 4701 RPM dropping 2299 RPM
Top Speed in 3 gear = 109.718 MPH
And changes into 4 gear at 5365 RPM dropping 1635 RPM
Top Speed in 4 gear = 143.156 MPH
And changes into 5 gear at 5667 RPM dropping 1333 RPM
Top Speed in 5 gear = 176.840 MPH
And changes into 6 gear at 5847 RPM dropping 1153 RPM
Top Speed in 6 gear = 211.710 MPH
Old 12-07-2006, 04:20 AM
NJHK's Avatar
Having an 6 speed won't benefit much.
You have to think price per gains. Is it worth going through all this for 1 extra gear?
There are plenty of ways to get fast than changing your transmission just so you have an extra gear for slightly better acceleration.
Old 12-07-2006, 04:55 AM
HunterKiller89's Avatar
a tad off of the subject, but i dont really think my question is worthy of its own thread...is there a site where you can find auto junkyards near you? i dont have a clue where the closest auto junk yard is...
Old 12-07-2006, 05:19 AM
NJHK's Avatar
www.car-parts.com can give you an idea
Old 12-07-2006, 06:24 AM
LowridaH's Avatar
dang
Old 12-07-2006, 09:33 AM
djt81185's Avatar
Since im converting my car to turbo the stock trans should work great...seeing as it was originally designed for a turbo car...long gears ftw!
RaginChopsuey
10-27-2015 01:27 PM
ThoR294
10-04-2015 08:44 PM
Extremespeed
09-29-2015 04:34 AM
ThoR294
09-28-2015 05:31 PM
z28addiction
09-28-2015 12:03 AM
Quick Reply: 6 speed for us?!?!?!
