Aftermarket Clutch Requirements
So I have finally decided to go with a Spec Stage 2+ for my set-up. But now I need to find out what all I need to get with the clutch. I think I need a new Master Slave Cylinder and new Throw Out Bearings. Is the correct?
Also does anyone know where can I get new throwout bearings besides the dealership?
A Fidanza OR SPEC flywheel will work with the OEM clutch and ANY SPEC clutch kit.
Last edited by TurboTechRacing; 10-03-2007 at 04:29 PM. Reason: Automerged Doublepost
turbotech could you clearify something, i was doing a search on the spec clutches and i hear that people were having premature failure because of something to do with the stock flywheel and the clutch doesnt really incorporate with it. can somebody respond to this???
Some good info in this thread: https://www.cobaltss.net/forums/drivetrain-79/need-some-drivetrain-help-exedy-clutch-77605/
I've got 37000, and I learned how to drive a stick in this car. So I'll probably end up getting new throw-out bearings from the dealership (unless someone else sells them). But I'm still undecided about the master slave cylinder.
