Alignment ??
Alignment ??
Does anybody if you can adjust toe on the rear of the cobalts. Either i wasnt paying attention but i didn't notice any tie rods or anything at all that can be adjusted to fix toe.
You "can" but its jury rigging at best. Alot of shops probably won't attempt to do it, but you can shim the hub.
Personally I wouldn't reccomend doing it either. You could try loosening the rear axle mount bolts and shifting it a bit to balance the toe on both sides.
DANRICKARD
10-01-2015 12:08 AM
