B&M short shifter help
Well last night i installed my B&M marked out the lines and everything, each gear feels smooth to shift into but 5th. I need to lift the reverse lock to get it into 5th and even when i do lift it its hard to get into reverse. This is my first time installing a short shifter so im new to it any help is appreciated.
I had to file on the lockout a little bit to give it more clearance over the factory piece when going into reverse. If you take your boot off and look where the lock out is at when you pull up onit and go to put it into reverse you will see where its hitting.
Look at where the cables are run to the bottom of the shifter, note the one that moves when you move the shifter left and right only. Unlock the plastic tab and adjust it so the shifter travel is slightly more to the drivers side of the car. Takes about 15 seconds to fix and no grinding or filing is necessary.
Originally Posted by poolboyz02
Could you or some please post some pics of where the plastic tab is?
hey thanks a lot for the help, initially i was gunna trim it down a little thanks for the advice. I'm also doing the extra shorty with the sparco shift knob same as 2k5ss/sc
Originally Posted by 05BlackCobaltSS
I guess i got lucky, becasue when i insalled mine, i had no issues. BTW: 2k5 your shifter looks badass.
SS_2009_TC
09-11-2015 05:41 PM
