B&M short throw help
Installed my sts and its very stiff its not smooth going into gears.
i have adjusted it all the time to try and fix it when i take the clips off and let the shifter free its very loose and smooth but when i hook it up to the shifting cables its very stiff my stock one was very smooth i dont kno what else to do
is there any play at all in the shifter, say when you're in gear, does it have a lot of movement?
you might need to check your ic pump... 181 is a bit high with you having a heat exchanger
SS_2009_TC
09-11-2015 05:41 PM
