Clutch and Motor oil!!!!!HELP!!!!!
Old 04-19-2009, 03:16 PM
ecotechcrazy's Avatar
Ok I just had a mechanic put a stage three clutch in my 06 ss/sc come to fine my car with no oil i look underneath to find my whole engine and tranny covered in oil anyone ever hear about a problem like this. and how can i fix it if possiable.
Old 04-19-2009, 03:18 PM
EatonTVS07's Avatar
was there a crack anywhere on the oil pan?
Old 04-19-2009, 03:20 PM
Not sure... how could that be if i did the clutch...
Old 04-19-2009, 03:24 PM
EatonTVS07's Avatar
well spray some break clean on it and see if theres a crack or something. who knows maybe the mechanic made a mistake of some sort or you hit something while you where driving.
Old 04-19-2009, 03:34 PM
Brian MP5T's Avatar
Changing a clutch is a really big job, many other parts have to come out..
Could have forgotten any number of things..
Old 04-19-2009, 03:37 PM
EatonTVS07's Avatar
with the job you dont take off anything that would make the oil drain from the motor. wait, is this tranny fluid or motor oil. maybe he didnt tighten the filler cap for the tranny tight enough or he didnt put the cvs shafts in good enough?
Old 04-19-2009, 03:39 PM
JimzSS's Avatar
Agreed , it is a big job.
But what would have been removed that contains engine oil?
Old 04-19-2009, 03:42 PM
EatonTVS07's Avatar
maybe its the tranny fluid, the type of oil wasnt specified
Old 04-19-2009, 03:44 PM
sport08's Avatar
thread title says motor oil
Old 04-19-2009, 03:49 PM
EatonTVS07's Avatar
nope it says clutch and motor oil it could be either one. and seeing as how he had his clutch done i am thinking its more likely the tranny fluid since you dont take off anything that would drain the motor oil (well i didnt anyways) or something could of cracked his oil pan while he was driving who knows.
Old 04-19-2009, 03:53 PM
sport08's Avatar
idk i read the title i think it the motor oil i dont c y u would say motor oil for the tranny fluid. but thats just me
Old 04-19-2009, 03:54 PM
EatonTVS07's Avatar
its still a dark looking oil in some cases. guess we'll have to wait to see if he cleaned it and found where it was coming from
Old 04-19-2009, 04:32 PM
Brian MP5T's Avatar
Taste it...
Old 04-19-2009, 04:54 PM
Its motor oil cause i had no oil when i checked the dip stick.
Old 04-19-2009, 04:57 PM
EatonTVS07's Avatar
have you talked to the mechanic about it yet? i'd hate to thing they dropped it or something
Old 04-19-2009, 04:59 PM
No not yet. i doubt i hit anything
Old 04-19-2009, 05:10 PM
EatonTVS07's Avatar
yea i'm pretty sure youd feel that lol
Old 04-19-2009, 05:49 PM
Brian MP5T's Avatar
I double dare you to taste it...
Old 04-19-2009, 05:53 PM
JimzSS's Avatar
he's yellow, he won't taste it
this is like solving a crime
if we knew what kind of fluid it is, we could help find the source
Old 04-19-2009, 05:57 PM
LSJAY's Avatar
Pictures !!!
Old 04-19-2009, 10:08 PM
domin8_gt's Avatar
I don't think it's tranny fluid. That stuff is thinner than oil, and looks reddish. What about the brake fluid? It's used for the clutch too. Was the bleeder valve tightened? It's on top of the tranny. If the fluid wasn't coming from the top, could it be from the small opening in the bottom front area of the tranny where the flywheel connects to the starter? Possibly could be a blown slave cylinder. I just did that with the Spec stage 3+ clutch.
Old 04-20-2009, 06:37 PM
Ok so its a crack in the oil pan. its from where the mechanic put the jack to hold the engine he denies it but it can be fixed with j b weld
Old 04-20-2009, 06:43 PM
shadowfaxss's Avatar
I was about to ask how the mechanic suspended the engine when he pulled the trans. These pans should not have anyting under them to support the engine. I went out an purchased an engine bridge to support the engine to pull the subframe and the trans. I wouldn't accept JB Weld......new pan IMO.
Old 04-20-2009, 07:56 PM
Brian MP5T's Avatar
Ummm, How about get a new one Champ..
Do you like your car?
Do you always want to worry that it's gonna Barf Oil all over then stop working?
Pony up and fix it proper..
Old 04-20-2009, 08:18 PM
JimzSS's Avatar
i thought about a cracked pan, but a "mechanic" should know better.
sounds like a back yard mechanic with a building over his head.
i would egg his sign
Quick Reply: Clutch and Motor oil!!!!!HELP!!!!!
