Clutch part # help
Clutch part # help
Hey guys, I have been having a little clutch trouble I'm hoping somebody can help me out with. I blew my clutch out doing something I shouldn't have a few weeks ago. So I took it in and actually paid for it since it was 100% my fault. The problem is that after a few weeks the clutch still does not feel right. When cold in the morning there is almost no pressure on the peddle and it is sometimes very difficult to get into gear even with clutch on the floor. I have taken it back to get bled once already and this didn't seem to fix the problem. The dealer says they may have gotten a bad release bearing, which I think is probably unlikely. I am starting to get the sneaking suspicion that they may have installed parts from a base cobalt or NA SS. Does anybody know where I could check the following part numbers they installed to make sure they are correct?
Cylinder 12583857
Flywheel 12584343
Plate 12583856
Plate 12589049
Thanks
Cylinder 12583857
Flywheel 12584343
Plate 12583856
Plate 12589049
Thanks
disk-12589049
pressure plate-12583856
flywheel-12584343
slave- 12583857
thats taken from alldata for a 2005 2.0l s/c vin p
it is possible you did get a bad slave cyl. the slave cyl. and release bearing are one peice. if you still have the problem, take it back there and tell them you want it fixed. if its a bad slave they gotta pull the tranny back out and replace the slave.
flywheel-12584343
slave- 12583857
