Clutch is really high
Old 01-20-2016 | 11:42 AM
Cwjohnson1995's Avatar
Recently I've gotten a new clutch installed in my 2006 cobalt ss/sc. Since it's gotten fixed the clutch engages at the very top, it couldn't be any higher. At times it feels the gear is slipping. The shop that fixed it says they removed all the air in the lines and they can't adjust the " sweet spot" any ideas on how I can fix this issue? Thanks
Old 01-20-2016 | 12:16 PM
exninja's Avatar
Is it definitely slipping?
Could it just be that the engagement is back to where it should be?
Old 01-20-2016 | 12:17 PM
blueLNFftw's Avatar
They are normally pretty high.
Is this a KY clutch?
Old 01-20-2016 | 02:03 PM
Originally the clutch was perfect when I bought it but ever since the replacement its way to high for engaging, they installed a luk clutch. I'm starting to think it might have something to do with the master cylinder because I'm losing small amounts of brake fluid.
Old 01-20-2016 | 02:21 PM
double clutch's Avatar
Crawl under and see if there is fluid leaking at the bellhousing
Old 01-20-2016 | 02:25 PM
I already had someone else check it out and they couldn't find leaks so maybe it's internal?
Old 01-26-2016 | 01:41 AM
firehawk618's Avatar
Fluid leaking is NOT going to make your engagement point high. It will make it low.
01-10-2016 11:46 PM
suprafanatic26
01-05-2016 09:09 AM
QuickSilver_SS
01-03-2016 02:12 PM
T-fog
12-30-2015 05:55 AM
Coupe DeCobalt
12-28-2015 06:49 AM
