View Poll Results: Downshift or neutral
Downshift
284
52.50%
neutral
257
47.50%
Voters: 541. You may not vote on this poll
Downshift or neutral??
Old 01-04-2008, 02:39 PM
  #276
Badju587's Avatar
I drive a lot at highway speed, and keeping it in 5th until high idle, 1250 seems to be a good area to push the clutch in, and then into 2nd until I finally stop seems healthy enough. It's not like you have to row the gears to come to a stop, and rev-matching (F&F turned me off to the term double-clutching) will save your snycros if you have the space in front of you to do it. Not seeing a problem with engine braking here.
I vote downshift.
Old 01-09-2008, 12:40 PM
  #277
Preowner's Avatar
Originally Posted by an0malous
what you are doing is called "neutral coasting"
and yes its bad. its unsafe, and illegal in places..
I strongly suggest you learn to decellerate properly with your car in gear.
I interpret him to be saying that he leaves it in gear until slowed down to 1300 rpm (rolling idle rpm) then puts it in neutral. Exactly as seems to be the generally accepted correct method. The only difference is he slips it out of gear once the transmission is unloaded without depressing the clutch.
Not sure how thats neutral coasting
My point would be that clutches are cheaper than transmissions. Use the clutch.
Though that argument could also be used for brakes vs clutch. Which seems to yield a marginally incorrect answer.
Yes I'm a newb. I always thought it would be useless to have it in the higher gears under about 1.7krpm since you don't fair much better than coasting when you need gas it. After learning all this I will make an effort to leave mine in gear for longer.
Old 01-09-2008, 05:47 PM
  #278
an0malous's Avatar
its possible he was talking about putting it in neutral at an idle, which is no big deal.
Downshifting is not about leaving it in higher gears at low RPMS like that.
downshifting is when your at highway speeds in 5th gear, and your coming up to a stopsign.
you downshift to fourth, revmatch, then release the clutch.
allowing the higher rpm compression of the motor so slow you down.
then downshift to 3rd
etc etc etc. until you are coming in in 2nd at a nice reduced speed, at which point you begin breaking, and shift to first once you reach a stop.
This is the correct way to slow a vehicle using engine braking and standard braking.
the WRONG way....is to put the car in neutral at any point in the slowing down process other than just before stopping.
Thats what i was calling "neutral coasting"
Old 06-09-2009, 02:54 AM
  #279
06SS ALL DAY's Avatar
would u rather pay for a clutch or brakes? simple choice
Old 06-09-2009, 02:55 AM
  #280
Original Hayden Fanatic
REIGN SS's Avatar
...oh god
Thank you for bringing back a nightmare, did you read the last 270 posts before you posted?
Old 06-09-2009, 03:03 AM
  #281
Knightwolf's Avatar
This is how I downshift/decelerate my vehicles and it's the proper way to do so safely.. the only difference I don't do is to downshift to 1st gear since it's so low anyways. Matching your revs is good for your clutch and your engine when you use the compression of the engine to slow you and it's the proper way to be ready for any possible emergency situation or under adverse conditions, etc. ask any professional driver.
I drive truck for a living and if you're in neutral coasting to a stop and it's slippery out.. you're putting ppl's lives at risk
/end rant
Old 06-09-2009, 03:39 AM
  #282
Originally Posted by REIGN SS
...oh god
no i did not. i submitted my choice on the poll and left my comment.
Old 06-09-2009, 04:16 AM
  #283
Acey's Avatar
You'd have to be hauling ass in 5th for 4th to be worthwhile for braking. From any speed in 5th I'll go to 3rd if I have a ways to go before stopping, if not right to 2nd. Sometimes you'll **** off the slushies behind you cause you'll start slowing and they won't see brakelights. Alot of the time as you're coming to the light while 2nd is slowing you, brakes won't even be necessary at all.
I knew the procedure for rev-match downshifting before I even got a car with stick, but I was still surprised at the "blip" it takes to go 5-2 if you're doing like 45-50. You've really gotta get the revs up there. Nice braking though.
Old 06-11-2009, 02:42 PM
  #284
2K5SS/SC?'s Avatar
I usually downshift if there is space to do so, but if not then neutral it goes. Also depends on how lazy I'm feeling that day or if I want to hear the exhaust.
Old 06-11-2009, 04:34 PM
  #285
CobaltVenomSS's Avatar
i made this awesome thread reign!!! lol
Old 06-12-2009, 05:59 PM
  #286
D4u2s0t's Avatar
spoken like someone who doesn't know how to drive a manual car, but thinks they can. I bet I replace my brakes less than you, and still have the stock clutch which grips just as strong as the day I got it. so i'd rather pay for neither, for a very long time.
Old 06-12-2009, 06:03 PM
  #287
CptTheAlex's Avatar
Holy dead thread revival man!!!!!
DOWNSHIFT GOD DAMN IT OR BUY AN AUTO!!!!!!
Old 06-13-2009, 10:33 AM
  #288
Permafried-'s Avatar
I'll vote downshift but it entirely depends on the situation I'm in.
Old 06-13-2009, 03:52 PM
  #289
RedBalt44's Avatar
i downshift all the time, even do some heel toe action
Old 06-14-2009, 04:30 AM
  #290
Nighthawk243's Avatar
Downshift. Gliding in neutral is asking for it if you need to jump on it.
Old 07-18-2009, 06:02 PM
  #291
listen to this guy lol
http://www.youtube.com/watch?v=cPj9X...eature=related
i thought i would bring this back lol
Old 07-18-2009, 09:57 PM
  #292
an0malous's Avatar
"dont downshift and let the car slow you down"
and then spend 10 minutes showing you how to downshift while hes slowing down
strange.
Old 07-19-2009, 10:46 PM
  #293
Agree with video...that's how I drive every day
Old 07-22-2009, 11:26 AM
  #294
ForsakenOutlaw57's Avatar
well ive heard a bunch of opinions on waht 2 do so im taking a poll..... When coming to a red light do u downshift to help brakes or put in neutal 2 help clutch cause brakes arent as expensive as a clutch
Neutral, brakes are cheaper and less headache, that's for sure.
Old 07-22-2009, 12:30 PM
  #295
DaBuzzard's Avatar
Rev matched downshifts DO NOT WEAR OUT YOUR CLUTCH!
Get it right and you don't need your clutch at all - although I suggest you learn with the clutch.
If you need to brake while downshifting, REV MATCHED HEEL AND TOE!
Want to save wear on your synchros as well? REV MATCHED DOUBLE CLUTCH DOWNSHIFTS. Only way you CAN downshift an older non synchro tranny.
Old 07-22-2009, 12:37 PM
  #296
chris88z24's Avatar
I am not even going to argue this because the morons who THINK they can drive stick but really can't... oops i've said too much.
Old 07-22-2009, 12:38 PM
  #297
DaBuzzard's Avatar
lolz, I couldn't bite my tongue anymore.....
Old 07-22-2009, 12:41 PM
  #298
slowswap's Avatar
Word. My 240 was a stick with a 6 puck clutch. If you didn't revmatch your downshifts, you'd be sideways in the road.
Heel toe FTW.
Old 07-22-2009, 01:23 PM
  #299
Blue_Balt's Avatar
I've been rev match downshifting my car now for almost 10000 miles and my clutch is just fine
Old 07-22-2009, 02:48 PM
  #300
Dunesk8r's Avatar
I'm a firm believer in rev match and down shift, alot of corners I brake very little or not at all. Match the engine to the gear box speed and it doesn't hurt the clutch.
Quick Reply: Downshift or neutral??
