View Poll Results: Downshift or neutral
Downshift
284
52.50%
neutral
257
47.50%
Voters: 541. You may not vote on this poll
Downshift or neutral??
That might apply to a road course, but when your on a highway, and something is suddenly in front of you or coming toward you, you don't have much choice but to try and stop. If you try to accelerate around it, your going to be in the ditch, another car, or the embankment. I mean, it's only two lanes most of the time, where exactly are you going to steer around something? Have you ever been in an accident by the way?
Personally, I do a combination of downshift and neutral, so I'm not really arguing, but how can you argue w/ the owner's manual? Your info. regarding an automatic transmission isn't entirely correct. You say it's always in the correct gear, but it's not magic. That would be a CVT. if your going 30mph in 4th gear, and step on the gas, the tranny is going to drop a gear or two so you can accelerate. Likewise, if you coasted to a stop from 60 mph in 4th gear, you're going to tell me that the tranny is going to keep it in high gear all the way to the stop? I don't think so.
I wasn't implying that automatics don't downshift, because they obviously do, I was referring specifically to the higher rpms. You never FEEL or hear the car downshifting, but it is doing it.
And as far as your MPG claim, you may get better gas mileage than most, but it would be even better if you always coasted to a stop. There is very little load on the engine when coasting (low RPMs), and downshifting keeps it in the 1500 to 2500 range most likely. It may only be a slight difference, but there is no way that downshifting is BETTER for fuel economy than coasting. It's simple physics.
Most of our roads are 4 lane here, so you've got two lanes of traffic in your direction and that's more than enough room to avoid something, so long as you're always aware of other drivers on the road. In ten years of driving, no, I have NEVER had an at-fault accident.
I double clutch and downshift. Zero clutch wear that way.
When you are not touching the gas pedal your engine is receiving zero gas if you are above a certain RPM. Not sure what it is for cobalts but for lots of cars it's around 1500 rpm.
I agree. Another thing people should think about is gas mileage. You're going to get better gas mileage coasting than you are downshifting. I don't think that it would be the clutch I would be worried about. Does downshifting at higher rpms hurt the engine at all? It seems like it would, why don't automatics do it?
As for Alleycat, I guess I misread your post. Obviously if something is AVOIDABLE, then yes, you may need to have the ability to accelerate. I was thinking more about the times when you know you are going to hit something. I have been in two accidents that were completely unavoidable, both times w/ elderly drivers pulling out in front of me, and I had nowhere to go. Luckily neither were in the SS/SC, but the wife's car.
http://en.wikipedia.org/wiki/Double_declutch
Although I'm not sure why it's called "double clutch?" Basically just match the revs to what they will be in the next gear, so that the shift is smooth.
I downshift, but never into 1st. I do it to rough up the clutch, and keep it strong, and to assist the brakes. 28k miles of ME driving, and still stock clutch and brakes. Both work fine. Brakes about 2/3-3/4 gone, but clutch seems fine.
My clutch usually only slips because it can't handle the HP, so I try not to accelerate hard from 1st-2nd.
1 Post
I personally do both, blip the gas to revmatch if im going to go WOT, or I slowly release the clutch until it is fully engaged if im just trying to downshift without going WOT.
#36
Coasting to a stop is not only dangerous but illegal in my state.
#38
Me...I like to keep the morons behind me! Yes, I am constantly speeding to stay ahead of trouble
So... unless I have to stop... I am accelerating around/away from the potential situation!!
I'd say at least 80% of the time I accelerate to avoid an obstacle, unless it's something completely unavoidable or I'm limited in run off room and can't maneuver as well. you're more in control of a car when you're on the gas than when you're on the brake. If you see something and jam on the brakes, you're at the mercy of your tires and the weight of your car is working AGAINST you.
Last edited by suburbanrobot; 05-14-2007 at 06:34 PM. Reason: Automerged Doublepost
#42
anyone who thinks neutral coasting is "a-ok"
pros- None.
safes gas? no
Saves engine wear? no
Saves clutch wear? no (providing you know how to rev match when downshifting)
Cons- Wears brakes much faster
- if you get rear ended youll take off like a rocket
- less control in an emergency
Its all together a reckless thing to do.
and whoever taught you that its ok needs to give their head a shake.
My job, and im sure most intelligent workplaces....will fire you on the spot if you are caught neutral coasting. whether in one of our 400 ton trucks....or a half ton pickup.
pros- None.
safes gas? no
#45
comin to red light i pop it out of gear and just brake...my synrchos got fucked up on my last car from downshifting frm 2nd-1st to a stop...it doesnt go right away,but after a period of time ur notice it
#46
cuz its horribly unsafe in alot of situations.
what if your coasting to a stop and you get bumped hard in the ass comin up to a red light.
you will get shot further into the intersection if your in neutral, because your freerolling.
Your engine reduces your brake distance.
being in neutral increases it.
what if your in an accident while your coasting and your knocked out.
your car will continue rolling if your in neutral.
theres an inordinate amount of situations where its just stupidity to neutral coast.
Its dangerous and illegal.
please dont do it.
please dont do it.
#47
#48
FYI, It is not good to downshift into first!!!! It is bad for the tranny...
#49
As for the coasting, I agree.....don't do it. I just never realized it was illegal. The people who usually coast will also probably notice their clutch slipping more. Just a hypothesis.
