Downshifting into 1st=Rough
the only time i downshift to 1st in in parking lots .but i have noticed the dead spot on 2nd , the car seems to just bog , and struggles to get back up to speed, i think it might have somthing to do with the stage 2 tune, becasue my wifes redline dosnt do it. i just take corners faster now ,lol
i don't get why people don't understand that shifting into 1st is bad while your'e driving. it's not meant for that. and the fact that you have to do tricks to get it into 1st should be an indicator of that.
I never downshift into 1st. If the car is moving at all I'll use 2nd. 1st gear in these things is only to get going from a dead stop. The only time I put it into 1st at all is if I'm stopped at a light or intersection.
Ideally, but I was saying in the case of going that speed like he said. Time arise when you don't have ideal time for second to slow you down in traffic. I personally hate to waste my brakes. Like I said though, if you don't know what you are doing it is better just to use the brakes than damage something that costs more lol. I was just explaining how it could be done smoothly.
+rep exactly
i down into first sometimes, took me a while to learn how to do it but i do it only when neccesary, as in going 5mph and traffic picks up i cant go in second i throw her into 1st rev her some and then ease that clutch
#37
I never said downshift to accelerate. I still can't understand what the issue others are having is though. My first is good up to 35mph from a start. I was watching closer today. I actually downshift when coming to a stop sign around 20mph. I don't have to force it. I don't have any jerking. No damage at all to the car. Believe as you wish though. It is a dead issue since you can't do it nor ride with me to prove otherwise. Anyone local though, I'll gladly take you for a ride and clear up the issue. I wish I had a video camera.
#38
Ive driven a few ss/scs and i have not found one yet, including mine, that doesnt have that "resistance" in first gear if you try to downshift to it above a crawl.
basically if your not slowing to a stop, and doing like 5mph, you shouldnt be downshifting to first.
all your engine braking is done with 2nd or higher anyway. by the time youd be ready to downshift to first, you should just coast-brake-stop-shift to first.
Unless you never liked syncros anyway.
#39
#40
This was the kind of situation I was talking about, I guess 15-20mph was an overstatement, 5-10 mph seems more like the situations I am talking about. I would never downshift into first at above that. I was referring to when you are slowing to a stop but not completely stopped yet or going into a tight turn. Downshifting into second just doesn't seem to pull you out well enough (at least on my car) without some significant bogging. At around 5-10 mph after coasting and wanting to get going again I will occasionally downshift into first after rev-matching to about 2.5-3.0k. Again not the smoothest transition unless you nail the right rpm for the speed you are going. I am hearing that this is not recommended though as it creates some serious pressure on the transmission. I guess I will have to stay in second from now on and just play the clutch a little more. Thanks for the heads up guys.
#41
you're welcome. you don't need the clutch till you're at less than 5 mph or so. you can coast at around 5 with no clutch. usually, if you're going that slow it's because there's traffic or a situation where you can't go that fast anyways, so if it bogs a little bit it's not a big deal. but still how long does it take to get from 5 to 30 in 2nd, maybe a second? it's not a long time.
