f35 parts break down
and since one bolt was hand tight i though it blew out the gasket
i don't know what else could be causing the leak if theres no gasket
no trans fluid by the bell housing or either output shaft seal
and the drain plug and fill plug are tight
not a freaking chance... lets see: remove rear cover; you can do that in car. undo case bolts and drive out pilot bushings...hard but not impossible.
hmmm remove fifth gear nut , ya. put puller on cluster gear no forget it... cant be done I know this just thought I would start the process... I will post pictures...later net is ds slo tonite
