Found axles !!
Found axles !!
hey you guys i have been searching for stronger axles for the ss sc for a while now that dont cost over $500 and i found them they are soppossed to be a little stronger then stock, they are made thicker. and their only 150 each any one interested
Are they from Cardone? I ordered a driver's side through a local shop and that's what they gave me for $160. I told the dealership what to do with the $550 they wanted for a stocker.
It has a larger outer cv and a thicker center bar they look alot like the stage 2 axles but i have no way of telling how much extra power they can handle but for cheaper then stock it sounds like a deal for me
ok guys i was only able to put the pics in my gallery as you can see they look the same as the drive shaft shop stage two if any one wants to stop bye and check them out let me no i am also going to put them on my car when my trans is finished ut i will have to no how many to order if any of you want to take advantage of this deal to
can you see the pics
well i managed to keep breaking mine and my father has a auto parts wharehouse so i just kept buggin him to find me new axles and after a lil bit this is what he came up with. i also took off an axle from my car to measure it up and the outer cv is bult bigger, and the shaft is 30thousands thicker
