GMPP Cobalt Wheel Hop Kit & Clutch Upgrade!
#201
wheel hop doesnt get eliminated from the smaller firmer bushings, if that were true the very firm polyurethane bushings would stop wheel hop, wich they dont. ottp mounts do stop the wheel hop, plain and simple. it doesnt matter what hpvo says, doesnt matter what gm engineers say, it stops wheel hop, and thats all there is to it. gm is saying in theory these mounts shouldnt stop the wheel hop, but i highly doubt they bought a set and tested them.
i read through the entire thread, and aaron, it apears your pissed off that another company is making a product that works. people dont seem to care about the cost (once they dropped the price, i bought mine imediatly) as long as it fixes the wheel hop, and it 100% does. i can say after all the attacks and bitching, the rear swaybar and koni yellows i was going to order from you next week are going to be comming from OTTP, and i will never even think about ordering a product from you, ever!
#202
#206
Haz l33t wheelz.
glad about the Patent.
Aaron, i think you need to back off a little, the public posting of the comments that were sent to you privatly was a very immature move.
#207
I will go on record here as saying that no one can make rotated mounts for the cobalts and ions for a long while as the patent is pending on the design. We have also gone to a billet design and they will be ready in 4 weeks. Our product is proven by our customers and the time attack cobalt not to have hop. Poly mounts have been proven by many to still have hop.
and that is a fact sometimes some people are a bit smarter then the engineers at gm
#211
You can still use the LNF axles for 05-06,early 07 cars, if you install a grand am wheel bearing from SKF which has 10 holes, 5 x 114.3 and 5 x 110 but you will need to clearance the 5 x 110 holes for the studs, and turn down the wheel centric hub to fit LSJ 65 mm wheel centers.
Late 07/08 cars have different abs wheel counts and that wont work for you, but for 07you may be able to use a rear solstice wheel bearing depending on the mounting pattern, but all this is too complex to screw with.
Koni cars use a hardened shaft which you can buy from the race teams and use grand am wheel bearings and grand am outer cv bells with the inner lsj plunge joint,and that shaft is a lot lighter. Early 2005 / 2006 Koni race Cobalts have Pratt and Miller made special ( $300 per )axle shafts made from the same material as the C6R ; they will never break.
The TTR upper mount is not a great idea to use with the OTTP mounts but some folks have done that...there is a lot of available movement in the upper mounting bolt holes on the mount to motor block on the passenger side, and the mount to transmission on the drivers side to reposition. It all depends on what you want. It shows pictures, and explains in the Ecotec Build book in chapter 3 pages 13 and 14 on the time attack car, that the rack was spaced for bump steer and the mounts were rotated for axle alignment. End of hop. end of story...
#213
agreed. this lnf axle deal only works if they change the wheel bearing like i do. but there is not any bearing in the kit. that means that they either made a mistake or have to do an LSJ bell with the weak sauce outer axle...oops....or an unobtainium metal bell
#215
pictures dont mean much but the pics of the axle shafts are not TC axles, which have much larger axle shaft diamter. So maybe they supply LSJ axles with stronger shafts, which is not a lot different from DSS shafts, and thy have broken in hop. So...no conclusion at this time. The TC clutch sure is better and priced right used for a season in Koni no issues...but then again road racing is waaaay easier on drive train than drag racing. 5 minutes of drag racing = 5 hours of road racing
#216
Haz l33t wheelz.
haha, very true.
but knowing how car maufacturers work, wouldn't it be cheaper for them to use TC axles with different bells, than to make a whole new shaft?
#219
Like I said it sucks that GMPP decided to wait till warranty was up on most vehicles before releasing these products. I snapped my axle shaft and left me stranded for a month till the DSS shaft came in and I had poly mounts and engine torque brace when mine happened. I won't even go back to the track till I get the new clutch installed so I'm not left stranded again.
I'm glad they have at least made it affordable for the clutch. I think the "wheel hop kit" is a little too much. My setup cost me around $800. Now I don't know if this "eliminated the wheel hop" at the track but i doubt it did. And I doubt it will with this "wheel hop kit" till someone shows a video of this kit installed doing a clutch drop at 2,000 rpm at the track with no "wheel hop"
Just my 2 cents
Just my 2 cents
#220
Just my 2 cents
Just my 2 cents
here ya go
#221
Haz l33t wheelz.
Just my 2 cents
Just my 2 cents
#222
Yep this is what mine does on the street with my setup right now .....BUT I want you to take it to the track with the same camera angle and see what you get with the same launch
Do that and prove that there is nothing but wheel spin like the video you have shown and I might think about this option.
Good luck
PS thanks for the video
#224
Good luck
Good luck
