How to check if a TOB is good?
Whats up everybody.. Just picked up a LSJ trans for my car from Mongorat, (cool guy). The trans already has a throw out bearing on it, Mongo said it was basically new, Im not doubting his word or anything, but just to be safe is there a way I can check if its good ot not before i put this trans in
Thanks everyone!!
Thanks everyone!!
Not that I know of but regardless, just replace it. It's not an overly expensive part and it's worth the peace of mind knowing you have a brand new one and won't have to disassemble the car again to replace it.
Also the trans is from a LSJ, I have a LNF... Does anyone know if that throw out bearing is gonna work for y car? It doesent matter that it's from a LSJ does it?
That means it's probably an LSJ tob and LSJ guys usually upgrade to the LNF tob because it is a better part. It will physically work but the fact that it is probably a lesser quality part is just another reason to swap it
What info do you want? Change it.
If you don't want to spend the money, leave it in there and take the trans back out later to change it.
The LSJ one isn't quite as strong as the LNF, as mentioned, so you should update it anyway.
As long as it is out of the car, you can't put pressure on it to test it's function anyway, so unless it was sticking or leaking horribly, you can't test it.
all the advice you are getting is right on. But you seem to be determined to go with that transmission that Mongorat sold you, ( a good part I am sure) and a good plan ( different ratio than LNF ) but with a used throw out bearing. If it works, fine, good for you. If it doesnt, we can all ask you " was it worth it?" because now you have to pull the trans out again....
I swapped TOB's when I did my trans back in February, from the one that was in the "new" trans, to the one that was in my old one. I was iffy about it at first, but have had no issues. I just didnt want to spend 160 bucks for a TOB. And as far as I know, besides the LNF, all ecotec TOBS are the same internally, although they may look different on the out side. The only thing is that the part going through the bell housing has to be swapped from cobalt to delta to jbodys
X2... seems kinda silly to me that you have an LNF but are going to install an inferior trans to it. technically it is the same trans but the final drive ratio is longer because thats what turbo cars like. and throwing in a used TOB is retarded. you have it out, do yourself a favor and buy a new one.
And has anyone done a LNf trans to LSJ swap? If so how different did the gears feel? Is it still like the LNfs? Like really good on the highway?
It's like a cobalt dick-measuring contest
Those guys never had LNF trannys with the longer final drive.
So the 3.82 is basically the same as the 4.05.. Just don't want my car to be significantly slower in the long run, I loved how the 3.82 gears were.
They can't compare. 100 rpms at cruise isn't gonna be noticable. They rev higher, so the gears top out higher anyway. Most LSJ's can rev to 7200 at least, I was at 7600 with springs. So I was finishing gears past the MPH where the average tuned LNF would anyway. Gas mileage is totally dependant on how you drive, and the DI motors are more efficent anyway.
