Hurst Shifter
#101
Originally Posted by SS_SC_Cobalt
mcz, what year is your car?
so far a lot of guys are able to put it in reverse without using the collar? Have you tried without?
hmmmm....
hmmmm....
#105
Originally Posted by RL-2005
mine will go into reverse without pulling up on the lockout
there are no bushings included
#106
I will ask this again...
Has anyone that has installed the shifter and has had problems contacted and heard anything from Hurst?? I don't really feel like installing a defective product if there is a fix coming.
#107
The Hurst shifter uses the plastic pivot socket from the stock shifter. This works fine and you will be very happy with the shifter once its installed. The only tough part is snapping the machined ball at the bottom of the shifter onto the socket of the shifter cable.
#109
#110
I had the Hurst shifter installed today by one of my buddies in my 07 SS/SC.
He said the same thing as others, knob was tough to get off and getting the cable back on was a bitch.
The reverse lock out works 100%. I cannot get it into reverse without lifting the ring. I check on the GM part numbers for the stock shifter and the 07 had a different part number from the 05-06 but when I checked with GM the 05-06 shifter superseded to the 07 part number so maybe there was some slight design change but I'm not sure.
As far as the Hurst goes I like it and would recommend. Finding 5th is a little different now but not a problem just got to get used to it.
#111
Has anyone noticed that this bushing is broken when installing their shifter? I just want to make sure that it is broken and wasn't designed like that. I need to get it replaced...
#113
Originally Posted by johnkb8
mcz34man pics
Originally Posted by Bhill0317
Just to let everyone know my hurst shifter is being shipped as we speek. The cost is $132.99
Heres the link
http://www.northernautoparts.com/Pro...tModelId=13303
Heres the link
#114
nope not broken on mine
that's cracked!
that's cracked!
#120
Originally Posted by gringojoe
Just got mine in the mail. Little nervous about the install. Mostly that my 2.4L doesn't have reverse lockout and the shifter does. I'm assuming that it won't matter.
Joe
Joe
#122
Originally Posted by leviticus88
Thanx, Any tips for the install? I've never done one before.
#123
Originally Posted by LewiSS
You can come over to my place and I can lend a hand. I've not done the Cobalt, but it should be similar to the other front drivers I've done.
When I get it I'll def. take you up on that. thanx
