Hurst Shifter
Old 11-05-2006, 08:23 AM
  #126
thunderbalt73's Avatar
my question is why is the reverse lockout working on some and not on others?? any body got a clue as to why? cause im not buying this till its fixed knowing my luck itll go in to reverse at 80 ouch~!!!
Old 11-05-2006, 05:07 PM
  #127
RpSS4844's Avatar
Do you try to find that elusive sixth gear a lot? perhaps speed shifting from third to fourth could get to be tricky huh!!!
I would rather the reverse LO not work, its kinda like having a dummy light for being low on fuel, if some peoples light were to go out, they would run out of gas all the time!!
There is too much whining and debate about this reverse LO. The Hurst is a superior shifter to those on the market with or without the reverse LO.
Old 11-05-2006, 07:19 PM
  #128
SS_SC_Cobalt's Avatar
+1
Old 11-05-2006, 09:23 PM
  #129
Allshot's Avatar
Reverse lockout probably isnt working becasue there not adjusting the cables correctly.
Old 11-05-2006, 09:50 PM
  #130
and how would this be done? the problem is the lockout doesnt reach the stock tab in the mount.
Old 11-06-2006, 11:08 AM
  #131
gringojoe's Avatar
confused
I ordered one of these for my 2.4L SS and I got the silver part off of the shift but there is no torque screw under it. Just some plastic piece. Has anyone installed this shifter in the 2.4L?
Thanks,
Gringo
Old 11-07-2006, 04:21 PM
  #132
well I heard back from Hurst, Spoke to Jim their Chief tech and engineer, he says they are aware of this problem. this part was prototyped on a car and worked fine, but they recently installed one in a brand new 07 and the shifter does not go into rev. with the reverse lockout.
It goes in without like a lot of us are experiencing.
they are working on this to determine what has changed/ or not changed that causes this.
Question:Anyone that has installed this shifter and do not have the use of the lockout, was your shifter EVER replaced under warranty?
Old 11-08-2006, 09:51 PM
  #133
automobiliben's Avatar
I put mine on tonight and the reverse lockout works...sort of. It is only time until the plastic wears down and the reverse lockout is useless. I have never had my shifter replaced, there is a bushing broken, but the ******* dealership is incapable on finding it. Miraculous when they hooked the scanner up it didn't find anything. WTF, what good would the scanner do, what a bunch of retards...
Old 11-13-2006, 08:03 PM
  #134
redss05's Avatar
Unhappy
i just got my hurst shifter for my ss/sc...anyone have a "how to guide" on how to install it because im clueless
Old 11-13-2006, 09:48 PM
  #135
hate to say it but follow the instructions they provide they are pretty accurate and easy to follow
Old 11-15-2006, 11:09 AM
  #136
leviticus88's Avatar
Originally Posted by LewiSS
You can come over to my place and I can lend a hand. I've not done the Cobalt, but it should be similar to the other front drivers I've done.
Well, It's installed. It was a bitch though! I misread the instructions and the linkage is all fucked up. I'm just stupid I guess.
I finally got it to where I can shift into all the gears but 5th is hard to find and Reverse is just weird. The lock out only half works. I'm going to play with it later and see if I can't get it adjusted better.
But, other than that 1-4th is amazing and it feels very smooth. If only 5th and reverse felt the same. It looks bad ass though!
Edit: I fixed the linkage and adjusted it. All gears feel awesome and the Reverse lock out works.
Old 11-17-2006, 11:19 AM
  #137
Have you heard anything back from Hurst yet?
Old 11-17-2006, 12:21 PM
  #138
not since they were working on it
Old 11-19-2006, 01:00 AM
  #139
lsjwannabe's Avatar
who has them in stock?
Old 11-19-2006, 04:41 PM
  #140
Coop's Avatar
So there is a problem with the Hurst shifters reverse lockout on the 06 SS/SC's?
Old 11-29-2006, 03:10 PM
  #141
RL-2005's Avatar
what did you adjust? the shift cable or the select cable? the large pivot ball can only be installed one way, right? It's sandwiched between the base and the upper plastic retainer.
Old 11-29-2006, 03:12 PM
  #142
thedubsack85's Avatar
idk what u messed up but it wasnt hard to put in the b and m on my redline..have to rememeber to put in the new washers.
Old 12-06-2006, 10:23 PM
  #143
black06ss's Avatar
my wife just told me i got mine in and she said it had a black knob that doesnt sound right anyone else get a plastic black knob on theirs?
Old 12-07-2006, 01:22 AM
  #144
RBC
RBC's Avatar
Well I just got mine in this week and it looks just like all the other pics I have seen, no plastic. As far as problems with how it works, I will not know until sat or sun.
Old 12-07-2006, 04:58 PM
  #145
redss05's Avatar
ive had my hurst in my ss/sc now for about a month...i love it but the only problem i have is i think its too long or tall...i know people have been having problems with the reverse lockout...mine doesnt work which is fine...what i was wondering is if it doesnt work...is there any way you could take the whole lockout off the shifter assembly...the hurst shifter that is?
Old 12-07-2006, 06:26 PM
  #146
alleycat58's Avatar
Thanks,
Gringo
I'm confused, you ordered a Hurst or a TWM?
Hurst is for 2.0 only, which might explain the problems unless you're trying to alter the Hurst to work on a 2.4 shifter, in which case you're gonna be on your own, don't think anyone's tried to tackle that yet.
Old 12-07-2006, 06:45 PM
  #147
CTORANGESC's Avatar
Yeah I just recieved mine today, and all I can say is I love it. Mine has a sweet graphite knob, I dont know about the plastic one from above. I won't be instaling it till next spring though seeing my car is in storage now.
Old 12-07-2006, 07:04 PM
  #148
Blown 4-banger's Avatar
Ok, where is the cheapest place I can get one of those bad boys. SRT-Killer is coming over to my house tonight to pick up my B&M. I'll be short throw shifter...less for a little while.
Old 12-07-2006, 08:40 PM
  #149
RBC
RBC's Avatar
black06ss, can you take some pics of the plastic ***? It sound like you may have recieved the wrong shifter, unless you wife is ******* with you.
Old 12-07-2006, 10:13 PM
  #150
black06ss's Avatar
well im a few thousand miles away from any short shifter. but the wife didnt open the package all the way just enough to see what was in the box. she said while it was in the wrapping it looked like plastic when i finally heard back from her i had already posted she said it was like the pics on this thread. so no worries now.
Quick Reply: Hurst Shifter
