I think I burned my clutch...oppinions????
Old 01-25-2009, 02:56 PM
krazycobalt's Avatar
Depends on what you have done to your car asweel, 100hp is goign to make a difference on how long the clutch will last
Old 01-25-2009, 04:05 PM
TurboTechRacing's Avatar
Most likely you did burn the clutch, you may have glazed the disc. The disc is most likely still thick enough, it just can't grab as well when it is glazed.
A few good clutch kits would be:
SPEC stage 3+ or the Exedy hyper single.
Old 01-27-2009, 09:57 AM
Large W's Avatar
would this help http://www.crateenginedepot.com/stor...2-P2301C0.aspx
Old 02-26-2009, 09:02 PM
ian48065's Avatar
Originally Posted by Large W
bump because i would also like to know if that kit will help or would it be better to go with a aftermarket assembly?
and would that work on a tc rather than the sc?
Old 02-26-2009, 09:07 PM
G5GT2007's Avatar
i blew mine with alittle over 20k on it. i learned to drive stick on this car i learned to race it on the 1/4. i was very lucky and gm put in a me clutch for me and picked the car up at the drag way. i didnt pay anything. the new clutch i have been good to because im not geting another free one.
Old 02-26-2009, 10:18 PM
ajjaro's Avatar
it says up to 300 horsepower, do they mean to the crank or the wheels?
Old 02-26-2009, 10:21 PM
cakeeater's Avatar
Originally Posted by Gabi
23k miles from stock clutch is not bad when you heard lot of stories from people here that it last 10-15k miles
you can also try spec 2+ i heard good things too, is not as good as the exedy but it doesnt cost a lot like the exedy niether.
spec = poop formed into the shape of a clutch, then painted. I went through 2 of them before i realized that.
crank.
Old 02-26-2009, 10:22 PM
ajjaro's Avatar
whats the best value clutch that can handle up to 300 to the wheels, i did some searching around, but there's always other options out there, anyone?
RaginChopsuey
10-27-2015 01:27 PM
TrevorB
09-14-2015 03:59 PM
RedBaseBolt
04-03-2006 04:04 PM
mkulrey13
03-19-2006 03:06 PM
Quick Reply: I think I burned my clutch...oppinions????
