I think I done f***ed up the transmission or clutch...
It started Friday, right after I left the Chevy dealership to see about the trade in...when I press the gas in first, it seems hesitant to engage and speed up. Then while in 2nd, it has a hard time picking up speed and stay at about 3-4 thousand rpms for a second, then slowly starts to rise, same with 3rd and 4th gear. While in 5th, it'll stay at 2000rpms, and if you press the gas it'll quickly rise up to about 3-4thousand rpms, then drop down to the 2,000, then finally start to rise again (like normal). Help please...any ideas? Is what I'm guessing right?
Well, while on the way to the dealership...the clutch or something locked up and the car would not shift into any gears. Had to have the car towed and it's at the dealership...hope nothings too bad...
No don't think that's what happened to you..., what ended up happeneing with me was that the clutch burned up and the dealership had to replace the pressure plate and get me a new clutch. Nothing that bad but it took a week to fix...
importkiller
09-30-2015 07:18 PM
