Ingalls ETD bent
#76
This thread has been here awhile and through all of this i have yet to see a pic of an Ingalls Bent.
and for this one "wow ingalls only gives a 90 day warrenty www.bwoodyperformance.com gives a 2yr warrenty on their motor mounts"
The whole point of the ingalls(as far as i know is to help support stock mounts. ) Those motor and tranny mount were ment to repalce stock parts and can deal with a lot more stress then the stock and the stock with ingalls. So far my ingalls hasnt failed me.
#78
Dave if you would like send an email to grant@ingallseng.com and Ingalls would gladly look at your unit. If the unit is damaged due to normal use Ingalls will replace or repair it free of charge. One quick question is it cold where you are?
I took off the end cap ( form the side that you adjust) and a big pile of black dust/elastomeric particles fell out. basically the black dampener portion inside the aluminum body had disintegrated.
I will ask Engalls if they can send me new internals, I can rebuild the unit myself.
if you look at my install pictures you can see I had it installed per the instructions and the unit worked GREAT for a long time. I wonder if anyone has had a similar occurance.
DANRICKARD
10-01-2015 12:08 AM
