Installed lnf trans mount and shift cable bracket
Well was bored today and these parts had been sittings in my car for the last 3 weeks so I. Said its time to install them!!
First was the shifter bracket I thought it would be easy removal and install but wasn't clips that held the cables to the bracket didn't wanna come off and had to drown it in p-blaster. Let it soak for a few and off they came. Install was a bit tricky screws didn't wanna line up so had the take the bracket apart and install that way.
Next was the rear trans mount I had the car jacked up on all 4 corners so in order to avoid any possible movement front to rear,side to side. Got the jack under the transaxle and put a lil support on it loosened top 3 bolts a lil bit the removed rear trans mount with a new lnf mount. Bolted it all together. Put her on ground and went for a spin no harsh vibrations car feels brand new and tight, shifter feels firmer some how just all around car feels good and tight.
Thanks here's a few pics nothing great.
i need to do this i have lnf mounts in my garage with 1k miles on em and im pretty sure my rear one is bad whenever i hit my gas and let off my car feels like its gunna throw the motor threw the hood and i already replaced the control arm bushings so this has to be it
jcalvin1126
09-11-2015 10:24 AM
