Intense Trans Inserts
Old 12-03-2006, 12:40 AM
tricky1's Avatar
Will they fit the 2.2's? I know they say they're for the LSJ. I just don't really want to pay the $300 for both of the ZZP mounts. Please don't turn this into a 2.2 v 2.4 v 2.0 thread please.
Old 12-03-2006, 02:13 AM
tricky1's Avatar
I ordered them. If I find out they don't fit I'll re-sell them here.
Old 12-03-2006, 11:05 AM
CobaltPerformanceParts's Avatar
If they dont fit let me know. We have started making inserts and full mounts for the autos. However if you guys dont have one that fits already out there we would be willing to make them also. The autos will be available soon.
Old 12-03-2006, 09:54 PM
BlackLS's Avatar
It's great to see that yous aremaking some more products for the automatic owners. So what all are yous working on and about what are they gonna cost?
Old 12-03-2006, 10:01 PM
Right now we are working on the transmission mount. We are going to be sending out first unit out to some individuals for testing. Im sure you will here about it on the forum. We are still testing and developing the units and price has yet to be determined. Our goal is to provide a push-in bushing and a full reinforced mount. We will try and keep you up to date as much as possible.
Old 12-03-2006, 11:02 PM
tricky1's Avatar
the main reason I was asking is the front mount looks different. the rear mount however is the same as the LSJ mount
^2.2 front mount.^
Old 12-03-2006, 11:36 PM
celicacobalt's Avatar
some automatic stuff would be nice.
Old 12-03-2006, 11:38 PM
HackAbuse's Avatar
What the ****?! is that mount plastic?!?!
Old 12-03-2006, 11:41 PM
tricky1's Avatar
I believe it could very well be, It feels like ******* plastic. Just checked it is plastic, with bushings for mounting to the trans.
Old 12-03-2006, 11:46 PM
HackAbuse's Avatar
Dude wtf?
Mines metal
Old 12-03-2006, 11:48 PM
tricky1's Avatar
Mines a Manual...dunno if that makes a diff...But thinking about it, I dont know if I could trust a plastic mount to take the shock if I were to put the poly insert in it. The rear is metal I dunno why the front is plastic though.
Old 12-04-2006, 12:39 AM
Eeek plastic. I wonder why the hell they did that!
Old 12-04-2006, 02:19 PM
player_1's Avatar
if one of your trany mounts is plastic, I'd consider switching to a solid or polyurathane motor mount like ZZP or JBP, or anything else available in the future
Old 12-04-2006, 02:54 PM
tricky1's Avatar
The ZZP mount doesn't fit on the 2.2. I'm looking into either locally having a metal mount fabbed then if I have to I'll use a 2 part polyurethane to fill the mount making my own solid mount. Then I'll use the Intense insert I have coming on the rear mount. If I don't do it locally I'll have Cobalt Performance Parts do it. I have it talked out with them.
Old 12-06-2006, 06:31 PM
tricky1's Avatar
Wellllllll....sonuvabitch.
I figured it would be too large, but it's actually a bit too small. There's about an 1/8 - a 1/4 inch of space between the mount and the poly, any suggestions on what to do?
Old 12-06-2006, 06:44 PM
tricky1's Avatar
Electrical tape FTW...I wraped the insert in tape until it would fit in the mount snugly.
Old 12-06-2006, 07:20 PM
Brandon97Z's Avatar
I don't know if i'd trust electrical tape. Maybe get some poly and fill it in. You just have to line up the insert in the mount right, even then i don't know if i'd chance something to go wrong.
Old 12-06-2006, 07:26 PM
e to the x's Avatar
I think you're going to regret that decision. You also completely void the point of having the mount in by adding the tape. Its just gonna add play. Hope it doesn't fall out while you're driving...
Old 12-06-2006, 07:55 PM
tricky1's Avatar
I don't see how it could cause a problem...I wrapped the tape tight and it's not like it's that major of a gap I filled. Also when I put the insert in it was TIGHT. I doubt there will be enough side-to-side movement to make the insert fall out of the mount.
Old 12-07-2006, 01:17 AM
South Central *********
JapEatr's Avatar
i so alot of suspension work trust me, not gonna happen, the stock mount being plastic and now without poper fit of bushing, it will fail violently\
the bushings i install usually require lube and a press or vice, THEY NEVER JUST SLIDE IN,
get a metal mount from a vender and get it modified to fit by measuring and machining
not some mickey mouse walmart toysrus drill job with bushings falling out
Old 12-07-2006, 05:23 PM
tricky1's Avatar
The rear mount is the same way too, the insert is too small. I can remedy that by buying the ZZP rear mount as that will fit the 2.2, but the front mount will more than likely require a custom fab job.
Old 12-07-2006, 08:05 PM
tricky1's Avatar
Ok, I've decided to be safe rather than sorry with my engine/trans sitting on the road. I took the front mount back out and got all the tape off of it.
Inside of the mount there is a lip that makes the diameter of the inside go down to 3 and 3/4" when I slide the bushing through the lip of the bushing fits snugly in there. so I'm assuming I'll need to build the inside of the mounts out to 3 and 3/4" somehow. The question now is how.
Old 12-08-2006, 04:52 PM
tricky1's Avatar
Okay, I just sent my mounts and inserts to Cobalt Performance Parts to see if they can come up with anything. Thanks guys!
Old 12-08-2006, 05:12 PM
No problem. We got your pm with the tracking information. We will give you a call as soon as we get them.
Old 12-13-2006, 10:15 PM
BlackLS's Avatar
So do yous have anymore news about the automatic tranny mounts like when you expexct to have them available?
Quick Reply: Intense Trans Inserts
