Just Installed BWoody Solid Front Trans Mount, and...
WOW!!!! I can't believe the difference. The car feels so much more solid than before. I'll say, that it is a feel that you either would totally like or totally dislike, as it is a bit harsh. I personally love the feel, and it honestly reminds me of my buddies M3 under hard acceleration. I also have the Ingalls TD, so that helps tighten it up, too. If you're not too into the vibration thing, I would certainly suggest poly mounts, but I LOVE this thing.
Matt Gandenberger
Matt Gandenberger
I've got BWoody's engine and front trans mounts... I love it!
You get used to the vibes... and the way they put down the power is crazy. I laid on it in 1st yesterday in the parking lot... put down a good 20 feet of rubber... zero hop.
I also really like the way it smooths out the 1-2 shift. No more jerking or bucking... it just burns rubber and moves.
ok stupid ? .. will this help on my 2.2 .. my motor shake's really bad with the AC on and it get's really annoying ..i was thinking of getting the TQ dampner / Traction bars and Tran's mount will these all help together .. any advice will be greatly Appreciated thanx
Last edited by TurboTechRacing; 08-13-2007 at 02:12 PM. Reason: Automerged Doublepost
does anybody know why the rpms keep going between 500 and 1200 or so when the a/c is on??? mine does it for a couple seconds, up and down up and down its like a damn roller coaster. at first i thought my ac compressor or something else could had been mess up but i guess alot of cobalts do it.
My butt was sore after...
I have the TTR trans mounts in now. Car almost no wheel hop. I had 0 wheel hop till last night, but it was like nothing before. I think the TTR Motor mount + Trans bushing might have been 2 of my fav mods!
It's the stage 2 tune... my car does it too... though I rarely ever use the A/C. I believe if you take it to the dealer and whine about it they have a fix. One of our club members was having this issue, got a reflash, and isn't having the problem anymore.
It dosen't bother me enough to get anything done about it... so meh.
If the guy with the 2.2L posted complaints about the motor vibrating a lot, surely a stiffer mount would help keep the motor from rocking...
However, those rocking vibrations move to the dash and the cabin of the car... which he might also be referring to, in which aftermarket would make much worse.
