leaking clutch fluid
Old 06-25-2008, 03:38 PM
jimbos'ss's Avatar
I knew it.
And you don't need to bleed both systems. The brake lines will still be full of fluids and will work just fine.
haha yah now that thats fixed i gotta find where the damn oil leak is coming from, fix one thing find another problem, and i gotta figure out which of the 3 dangling plugs that are not hooked up goes to the tranny heat sensor, this **** is getting so frustrating!
Old 06-25-2008, 04:14 PM
Darkmanx's Avatar
yoour mechanic is a ***** and you need to get your money back.
Old 06-25-2008, 05:53 PM
jimbos'ss's Avatar
haha............if i wasn't so damn pissed right now that would actually be funny to me.
well found the ******* leak, goddamn oil cooler is leaking like a siv while i was under the car i found that the turbo only has 3 bolts holding it to the manifold and 2 of the 3 are loose as **** every ******* day i find a new ******* deficiency with this car, goddamnitt!
Old 06-25-2008, 05:59 PM
Darkmanx's Avatar
Who build your engine ? chevytech?
Old 06-25-2008, 06:01 PM
jimbos'ss's Avatar
howd you guess......
GermanKat's Avatar
that's the one
Old 06-25-2008, 06:06 PM
jimbos'ss's Avatar
ahah just found out the goddamn gasket set is on national back order, so now WTF am i suppossed to ******* do! goddamnitt
Old 06-25-2008, 06:07 PM
Darkmanx's Avatar
for some odd reason all the messed up build engines on here seem to be releated to him. but he builds a damn good engine for himself.
GermanKat's Avatar
take it we're not gonna ship it on monday then?
Old 06-25-2008, 06:12 PM
jimbos'ss's Avatar
how? there is no ******* way the car is gonna pass inspection to get on the ******* boat! gotta reschedule again, and hope they'll go for it!
which one would that be, i'm unaware of any engines he has built for himself?
Old 06-25-2008, 06:19 PM
  #36
Darkmanx's Avatar
his own???
Old 06-25-2008, 06:23 PM
  #37
jimbos'ss's Avatar
his own???
nope
Old 06-25-2008, 06:26 PM
  #38
Darkmanx's Avatar
nope
makes it even worse now. why is the car leaving the country anways?
Old 06-25-2008, 06:28 PM
  #39
jimbos'ss's Avatar
i'm getting stationed in germany, thats the biggest reason i went ahead with the build was so i could have a fast car for the autobahn and nurenburgring. not a leaky POS that i can't even ship!
Old 06-26-2008, 12:54 AM
  #40
jimbos'ss's Avatar
well i fixed the leaking oil cooler with some hight temp orange copper sealant, sealed it up great. the first time the car has been leak free since i got it back. now i gotta get a new bolt for the turbo and get those properly torqued, among other little ******* issues i gotta fix. so i put some oil back in there, was 3 ******* quarts low. i'd have been so pissed if the motor had siezed! good thing i'm a strong believer of constantly checking the fluids on a daily basis.
Old 06-27-2008, 02:26 PM
  #41
jimbos'ss's Avatar
damn you fix one leak find another that little 4 bolt plate on the front cover for the oil pump gears is leaking too. damn dp has en exhaust leak coming out of the welds, discharge flange is missing a bolt. charge piping is pushing down on the plastic wheelwell liner and pushing it onto my tire. missing all 6 torques bolts for my injector cover and coil cover. missing both brackets that hold the wheel well plactic liner in place. missing all clips that hold the upper grill to the radiator support. those are the deficiencies i found last night alone. i found a few previously that weren't even listed yet. charge piping doesn't clear the valve cover, doesn't clear the alternator, doesn't clear the hood. the maf piping was supposed to be 85mm all the way to the tb, but was reduced down to 2.5" before the tb. and there is no catalytic convertor. the bung for the egt guage was not welded in. and the bung for the wb and rear o2 sensor was not welded in. wow thats a lot of **** i gotta fix, to think i paid alot of money to have the charge piping and dp done for me. as well as the motor being built.
Old 06-27-2008, 03:15 PM
  #42
GermanKat's Avatar
you sure you didn't miss anything in the write up?
Old 06-27-2008, 03:31 PM
  #43
jimbos'ss's Avatar
there's a couple of other things but i can't think of all of them right now.
Old 07-03-2008, 02:16 AM
  #44
cblt12's Avatar
wow sucks about all the trouble jim... is "the builder" taking any responsibiliy?
Old 07-03-2008, 02:18 AM
  #45
jimbos'ss's Avatar
haven't heard from him, not really trying to either, got lot of the stuff fixed myself over the last two weeks, car goes bye bye wednesday now that i got it to stop leaking.
Old 07-03-2008, 02:21 AM
  #46
cblt12's Avatar
good to know you got it to stop leakin
Old 07-03-2008, 02:24 AM
  #47
jimbos'ss's Avatar
yah there was 3 bad seels and 2 bad gaskets total. all replaced now. so are you in town this weekend? it's my last weekend here, i will be down in sd friday, maybe saturday and sunday too depending on whether we pull a motor or too.
Old 07-03-2008, 02:29 AM
  #48
cblt12's Avatar
yup im here all weekend... i will be outta commission friday but if you are still down there sat and sun, i could head down.
Old 07-03-2008, 02:31 AM
  #49
jimbos'ss's Avatar
cool, if we end up pulling some motors you could end up with one hell of a good learning experience.
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: leaking clutch fluid
