lets play the 'whats that clutch / transmission problem' game!
Old 11-18-2013, 11:27 PM
i may try to record and upload a vid since these descriptions never really do a problem justice.
problemos:
1st and most alrming one: when flooring it, mostly in 2nd & 3rd, a bad grinding type of noise. definately drivers side so assuming trans/clutch related.
2nd: while decelerating mostly and now even when accelerating, i am hearing a slight repeating thumping noise, that slows down as the car does. sounds alot like when a rotor is warped but i know the rotors are fine.
3rd: after pulls i often smell burning and i think it smells like burning clutch. car doesnt 'slip' however.
4th: its slowly been getting harder more often to get into 1st and reverse
my buddys telling me possibly a t.o.b. / clutch disc issue.
car had new gmpp clutch kit with other stuff put in maybe 20-30k miles ago. im a good driver (dont burn clutch much) but i do ride her hard
Old 11-18-2013, 11:29 PM
thedude411's Avatar
have you tried slowing down in neutral to see if it is still making noise?
nhanson's Avatar
For sure not a wheel bearing?
Old 11-18-2013, 11:32 PM
buildmeanempire's Avatar
I don't know the problem but I do know the solution and it can usually be found in Saab 9-3.
Old 11-18-2013, 11:46 PM
doesnt matter if im in gear or neutral for the thumping noise. but for the most part it was only making the noise when off the gas. which made me decide it is not a wheel bearing, though those may be bad as well :lol
fking cobalts...
love the suggestion bro id love to bite that bullet at be done with this f35 bullyshit trust me
Old 11-19-2013, 08:37 AM
any other takers
Old 11-20-2013, 12:47 PM
well guess ill be dropping the cradle this winter and ill find out then hopefully.
Old 11-21-2013, 09:09 AM
buump
Old 11-21-2013, 09:19 AM
1st problem: Could be shaft end bearings or those specific gear’s needle bearings.
2nd problem: sounds like a bad wheel bearing to me
maybe take a look at the fluid level/type.
miles?
Old 11-21-2013, 09:31 AM
blueLNFftw's Avatar
What fluid did you pput in when you did the clutch job?
Old 11-21-2013, 09:39 AM
i put in the redline zzp fluid when i had my clutch changed; haven't checked the level
cars at 74000. clutch and all components are at about 25k miles of use
Old 11-21-2013, 09:49 AM
blueLNFftw's Avatar
Meh. I would and did OEM. When I was reading the consensous was OEM on these pieces.
For what it is worth, my GMPP has a little burn smell to it occasionally. I never have a grind though.
Old 11-21-2013, 09:58 AM
I would like to buy a vowel.
Old 11-21-2013, 10:04 AM
oh another thing its slowly been getting harder to get into first and reverse this morning it took me a good minute to get it in reverse
Old 11-21-2013, 10:05 AM
Check your wheel bearings first. Im sure you know how to check those. Obviously start with the simple stuff, good visual check, etc.
Old 11-21-2013, 10:09 AM
That could have to do with the fluid. Theres no real way to check it though besides draining and refilling. Just measure to check all ~2 quarts are there. And the color is red.
Also could be linkage related but would be odd for it to be only 1st and reverse.
What kind of motor trans mounts to you have?
ive checked them they seem to be 'ok'
they don't make much noise when in free spin and there isn't excessive play - though i have no 'good' bearings to compare them too
i have before assumed they were shot - because cobalt
Old 11-21-2013, 10:11 AM
stock motor mounts
powell trans mounts
zzp axles
gmpp clutch, new oem flywheel, new tob, clutch pipe etc
redline mt90 fluid
lnf shifter linkage
twm short throw
Old 11-21-2013, 10:15 AM
Go inspect everything thoroughly and report back :p
Old 11-21-2013, 10:24 AM
Also the weather could be causing the hard shifts when its cold. Happens to all manuals, mine is kinda rough until it gets warmed up ya know
Old 11-21-2013, 10:27 AM
Not sure if this is related to your problem but when it's cold out I have a real bitch of a time getting the car into reverse when I first start it up.
Old 11-21-2013, 11:16 AM
Very true. Be easy on the trans when is cold haha.
Old 11-21-2013, 12:43 PM
ya its usually cold when i have the reverse issue. as for first its just random; the solution is shifting into second, then back into first
Old 11-21-2013, 01:08 PM
donkeyballs's Avatar
Try going in 3rd then reverse/1st when it's cold. I always did this regardless of temp to slow the shaft down.
Old 11-21-2013, 02:10 PM
Nfamous60's Avatar
Usually get a nasty clanking.sound.when going into reverse sometimes have to.roll the car forward then bring it back into reverse.seems common on cobalts
Quick Reply: lets play the 'whats that clutch / transmission problem' game!
