Loose shifter
Loose shifter
My shifter is progressively getting more play in it. I can wiggle in left and right when it's in gear and I was wondering if there is a way I can tighten it? I rather fix my stock shifter then getting a new one
I know you say you dont want a new one...but a TWM STS is really crisp and tight, feels great. But I would remove the the shiftboot and console around the shifter and try to see where the slop is coming from.
It's a GM part. GM ACDelco - Revised Shifter Bracket for LSJ #GM-55563732
im at work now I have noticed this wobble has gotten worse. Im going to open up my box and see whats up but updating my brackets and bushing wouldnt hurt esp. since they arent hat much.
How bad are these to install??
It's the spring on the shifter. Swapping in a twm or bps sts won't fix the issue. Your going to need a new shifter assembly. I got one from mongo a while ago and all my shifter sloppiness went away. I dug at it hard a year or two ago to figure out the exact cause. Lol
Base bushings or cable clamp won't help much either.
