Lsd
the money should be used else where unless you have the $$$ to blow... you really only need it if you are pushing a good amount of power about almost 300 hp mark iwould guess and there is a phantom grip LSD out there for the balt and it is like $1000 or more
I would say go with the LSD because if you like to go fast like me then that is a great investment because if you are turning and you are going farily fast then the LSD will transfer the most power to the wheel with the most grip. I vote for the LSD.
I got mine without the lsd and I like to have one in the future. Has anyone looked into getting a transmission from a damaged ss/sc with the lsd already installed? And how much would it cost to have one installed in mine if I just bought it outright?
get lsd!! only need it if you are pushing 300hp? is that crank? because that's not hard at all. but anyways with my mods i still can't go more than 1/2 throttle in 1st because it's just wheel hop. right wheel spins like crazy. and that's with both prothane mounts and the ingalls.
importkiller
09-30-2015 07:18 PM
