LSD Transmission Swap
Old 05-07-2014 | 12:09 PM
Mercenary Mechanic's Avatar
What is involved in using a stock LSD transmission from a 2.0L and installing in a 2.4L NA SS??
Has some one done it?
Does it require changing to a 2.0L flywheel and clutch??
Ecotec block is modular and appears the same.
Diagrams seem to match.
Want to be reasonably sure before I buy transmission.
I am replacing transmission anyway.
Old 05-07-2014 | 12:19 PM
andrewcarr1993's Avatar
They don't really swap out, 6 vs 8 bolt flywheel is the main issue. It might work with a custom flywheel.
Old 05-07-2014 | 01:47 PM
Flywheels are same diameter on the outside diameter, aren't they??
The transmissions bolt to engine block to bell housing those are the same correct?
05-28-2022 04:47 AM
ThoR294
10-04-2015 09:44 PM
importkiller
09-30-2015 08:18 PM
Iceberg
09-29-2015 01:33 PM
Iceberg
09-28-2015 02:31 PM
Quick Reply: LSD Transmission Swap
