Motor Mounts
Motor Mounts
I was looking into getting motor mounts. What aftermarket motor mounts are every1 using and how is the vibration in the cabin after they are installed?
I was looking into:
http://cobalt-addiction.com/performance.htm ZZP Engine and tranny mounts
or
http://www.torqueforward.com/page2.html Their filled mounts
or
http://bwoodyperformance.com/product...cd83c7797fdc16
Please feel free to let me know what you think
I was looking into:
or
or
I have the ZZP Billet Engine Mount and Poly Trans. Mount. Combined they killed about 90% of my wheel hop issues, but left me with a good amount of vibrations. Haven't used the other two so no opinions on them.
We just released ours, you should check them out! Many options to customize them to your needs.
On the website look under "Chevy" then "Cobalt" then "Drivetrain"
Very very nice units at a great price!
Just the ZZP engine mount and control arm bushings took out ALOT of the wheel hop and I could hardly tell a difference in vibrations. Adding the front tranny mount eliminated wheel hop altogether, but created tons of vibration, felt like I was driving a freight train. Took a couple months for the front tranny mount to loosen up a little (and maybe me getting used to it) and now the vibration is not too bad, almost tolerable even. If your worried about vibration, my suggestion is to start with the control arm bushings and go from there, they seemed to make the biggest difference on my ride as far as controlling wheel hop.
with the TurboTechRacing one you dont need a damper as it will eliminate flex all together, it explains more in the threat about the release of the mount
We also have ours on sale front and rear ones. They go for 120shipped and you get a choice of three stiffness grades.Street Street/Race and Race
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/tags-new-billet-front-rear-engine-mounts-46215/
http://www.tagracecraft.com/COBALT.Engine.htm
Are the Bwoody ones really that good? Has anyone used the TurboTech mount or the Jbody mount. Trying to decide which to get before I start buying parts.
I really like the look of the JBP one though....
i was one of the people in the first batch of Turbo Tech mounts that went out, very happy with the quality of the product and it does its job well. Well worth the money! Service is A+ too.
I have the BWoody solid set in my car. They are great, the side and tranny mount were really easy to install, had a little problem getting the rear mount in but it would have been a pain with any mount since its a tight fit. They do give a good amount of vibrations but u get used to it. They do there job and get rid of the wheel hop, i highly recommend if you can deal with some extra cabin noise
sounds to me like the turbotech one it will be, nothing but rave reviews all around, prolly match it witha set of TAG lowers
Speaking of which, the TAG transmission mounts are available in different hardnesses of poly? Where on their site can you select which hardness you want?
look at www.cobaltperformanceparts.com and they have some excellent mounts that i have and they work great with minimal vibes! also the prices are really good i think 29.95 each, so like 60 for both and these are the same quality as every other vendors stuff but at way better prices...check them out man!!!
i have intense mounts and control arm bushings and they got rid of all wheelhop except sometimes when its wet outside. they did vibrate quite a bit at first but not after their broke in for about a week.
They carry the prothane trans bushings, just like we do at the same price we sell them at, however we have been buying everyone prothane makes, make sure CPP have them in stock...
We have them in stock at all times as we purchase 100's at a time.
ThoR294
10-04-2015 09:44 PM
n20saturn
09-30-2015 01:26 AM
