is it my clutch??
Old 01-02-2014, 03:58 PM
blueLNFftw's Avatar
Originally Posted by Legion
I would recommend the Redline stuff from ZZP that helps alot. Sorry for the hostility it's a repeat affair for most and your new. Go at least a decent brand. As for grenading the engine, umm no. You have to remove rev limiters, and on a car that is restricted I doubt it, it is possible but fringe science kinda way. Be careful with the throwout bearing if your doing it yourself, the heads of the screws strip easy with that hex. If you get a heavy clutch the adjustable clutch rod is worth it. And while breaking in the new clutch try to avoid freeway use if possible, the inconsistent RPM's will help seat the clutch. I advise shifting about 3K rpm from then on for max clutch life.
OEM fluid
Adjustable clutch rod is a terrible recommendation
Old 01-05-2014, 05:21 PM
Manny5569's Avatar
If my trans went out I should.be able to even go into any gears right? Cause I pulled out the clutch and clutch looks good but fly wheel looks pretty good to well enough that my car would.of still been able to move
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
SSLOW06
10-01-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: is it my clutch??
