New clutch master cylinder, blows clutch line off when trying to bleed?
Old 04-07-2019 | 04:56 PM
Jrflint09's Avatar
I have a 2005 cobalt ss, all stock. New clutch, slave and TB. Lost clutch pedal about 500 miles after new clutch install. Just installed a new clutch master cylinder. I have vacuum bled it and still cant get any tyoe of pedal. When I manually bleed it, it develops a hard spot in the pedal and when I press it down it blows off the clutch line that is attached to the clutch master cylinder. And the clip is installed correctly i have already checked. Any help would be greatly appreciated.
Old 04-07-2019 | 07:27 PM
63 Nova SS's Avatar
Are you totally sure the clip is correct? It's really hard to tell sometimes till you put the pressure to it.
Old 04-07-2019 | 07:34 PM
Jrflint09's Avatar
Yes ive taken it complet9off and reinstalled it, I even tried using the the clip off of the old one still no luck
Old 04-07-2019 | 08:14 PM
C0balts5's Avatar
Maybe the clutch line itself is faulty, the clip is probably being installed correctly but the locking grooves the the clutch pipe itself are boogered. You can get a new clutch line off of zzp performance website
Old 04-07-2019 | 09:12 PM
Jrflint09's Avatar
I just ordered one from zap so i will let u know as soonnas it gets here and I install it
Old 04-07-2019 | 09:13 PM
Jrflint09's Avatar
Zzp
Chevy_life2146
12-09-2015 01:02 AM
etnies
12-15-2012 07:57 AM
Iam Broke
03-11-2012 05:48 PM
cobaltshawn
05-11-2011 10:50 PM
DeepBlack SS
09-26-2009 04:03 AM
