New clutch, round two!
Old 12-18-2015 | 03:36 AM
firehawk618's Avatar
So I had to replace my trans a month ago or so. I was blindsided with having to do it the following day because my access to a lift was going to be taken away for over a month and I wanted to get this trans replaced.
That basically forced me to find a clutch locally to get the job done that weekend.
I ended up finding a parts store locally that claimed to have the stock clutch for an 09 SS so I paid too much and picked it up. I wanted a new clutch on hand as I had no idea what was in the car nor did I know if it was part of my high rpm shifting problems. Whatever clutch is in there has an extremely low engagement point so I figured there was a small chance this was part of my shifting issues.
Pulled the trans and figured out it had a clutchmasters FX300 + aluminum flywheel in it.
I didn't want to take any chances so I put the new "stock" clutch in the car and left the aluminum flywheel in there. I didn't anticipate the need for a flywheel or I would have bought one in advance.
The LUK clutch I picked up locally and put in has a self adjusting pressure plate.
Get it all together and wouldn't ya know this don't hold torque in 3rd at all. I gave it plenty of time to break in and it just isn't going to cut it.
Did some research AFTER the fact and wouldn't ya know it appears the LSJ came with the LUK self adjusting setup and we all know the LSJ clutch is less capable than the stock LNF clutch. Damn.
So I picked up a STOCK LNF clutch. OEM, from GM. Sachs NON self adjusting PP.
I am well aware of the GMPP LSJ upgrade. CED said don't do it. Yeah I know there's a billion people who did and it works fine. I get it.
I pm'd several people on here who chimed in on stock LNF clutches holding plenty of torque and got confirmation from many that the stock LNF holds fine.
I figure as long as I give it proper seat in time along with a new steel flywheel I should be in business.
I am self tuned, full bolt on, stock turbo.
Got my fingers crossed that this will be the last time I pull my trans for a while!
Old 12-18-2015 | 02:37 PM
Sl0wbaltSS's Avatar
LSJ upgrade clutch with a new LNF flywheel holds stock turbo full E well.
Old 12-18-2015 | 11:44 PM
nathan112i's Avatar
i found the stock clutch is actually really good! in fact i thought for sure it was going to start slipping at 400+whp but its still holding strong. if you can keep from launching/no lift shifting and keep power coming in linear the stock clutch is surprisingly capable
Old 12-18-2015 | 11:48 PM
No fun lol. I like kevins setup, stock disc, heavy plate.
Old 12-19-2015 | 12:31 AM
I'm hoping my clutch hold that power with the k04r
Old 12-19-2015 | 05:22 PM
nathan112i's Avatar
having driven his car i will agree it is a good setup and felt very close to stock
Old 12-19-2015 | 09:23 PM
What plate is kevin using?
I have a Clutchmasters plate here still that worked fine.
My only concern is with the FX300 the engagement was right on the floor.
I don't know if this is the PP or the thinner disc causing this.
Old 12-19-2015 | 09:38 PM
KMO43's Avatar
I have a Southbend Stg4 with stock disc on a Fidanza flywheel. It holds all the power I have thrown at it and engages really smoothly so launching for a race or just DD in traffic works great. I have a plan I am gonna go with for my next setup but I hope this lasts for a couple more seasons
Old 12-20-2015 | 02:11 AM
Thanks for the input guys.
Does anyone here who's HPT have their torque vs rpm vs gear ramping they'd like to share for me to try once I get this in?
Old 12-20-2015 | 06:43 PM
KMO43's Avatar
Send me your tune to take a look
firehawk618 (12-20-2015)
Old 12-20-2015 | 07:07 PM
Here's work in progress.
I have only been focusing on MAF scaling. I am damned close now but cannot do any WOT runs because of.....clutch issues! lol
File Type: hpt
Old 12-20-2015 | 07:25 PM
KMO43's Avatar
That's good I would change that 95% to a 96% but that's it. What fuel do you run?
Old 12-20-2015 | 07:51 PM
Just pump gas. IIRC 92 octane here.
I will raise that 95 to a 96
Do you recommend fooling with the following table?
Old 12-20-2015 | 08:01 PM
KMO43's Avatar
I use that table only for traction purposes. And i throw a ramp on 5th cause I've blown it twice.
On mine 1st is 75 to 80% and 2nd is 85% but i have bad spin in 2nd so i have to adjust
Old 12-20-2015 | 08:05 PM
Yeah I can't get any traction in 2nd either. I will fool around with this table and see how it feels.
Thanks for your help!
Old 12-20-2015 | 08:26 PM
KMO43's Avatar
No prob! The best way to tune those is just lots of runs and see what works best
firehawk618 (12-22-2015)
Old 12-22-2015 | 02:52 PM
T-Man's Avatar
You made a great choice. The stock clutch is rather robust for a stock unit and can handle quite a bit, so long as you aren't trying to make boost under 2K RPM
My stock clutch has 54K miles on it and holds my E40/K04R. My Dad put in a brand new stocker that I had laying in wait for my car when he blew 5th gear and was forced to replace the transmission (lucky SOB scored one with less than 3K miles on it) and it holds his E40/K04R as well. His cal is a bit more aggressive than mine and zero slip, even with NLS
If I were you, I would further massage your MALT table so that it's not requesting input from your further right columns of the DAL table during normal driving, especially if you've modified it, which you have. I would suggest starting over with a stock DAL table and working from there. There is no reason to be requesting over 255 now that we have all of the proper tables available.
I would DEFINITELY recommend using the Max Torque x Gear table to smooth out any boost spikes and to keep **** from breaking. To be honest, it's going to be one of the most powerful torque reduction tables available to you. Anything else affects overall boost in all gears. With this table, you can set your targeted boost level and then go about smoothing/reducing from there. Here's mine for example *I wouldn't recommend just using my inputs as it's tailored to my CAL/other tables*
Old 12-22-2015 | 04:39 PM
KMO43's Avatar
What are your WGDC set to?
Old 12-22-2015 | 06:27 PM
That's very encouraging for me as far as the clutch goes. Thank you.
I am going to take a good look at the MALT and DAL tables as you say.
Are you saying on the DAL that it should be zero's when cruising / under no load?
Thanks again for any input on this.
It's set to 95%
I followed some very old LNF tuning guides and do appreciate any and all input!
Old 12-22-2015 | 10:18 PM
KMO43's Avatar
I use no boost ramp on my car it's all done by wgdc
Old 12-26-2015 | 10:11 PM
Got the new clutch in.
The feel is great and I gave it almost zero break in time and it's holding just fine!
Now to work on the tune......
Old 12-26-2015 | 10:39 PM
KMO43's Avatar
I hate logging my car
Old 12-26-2015 | 10:55 PM
lol so do I.
I wish the HPT pro cable had more on board memory.
Do you or anyone reading this thread have a maf scaling for a K&N they don't mind sharing?
I put the K&N on the other day and removed the HAHN. I had the HAHN dialed in nice but now I get to start over.
I do not like the low mounted intakes in my area. Simply too much rain here.
If someone would share their MAF scale I would greatly appreciate it. It will save me a bunch of time and give me a nice base to start from.
Thanks in advance.
Old 12-26-2015 | 11:26 PM
KMO43's Avatar
I do PM me
firehawk618 (12-27-2015)
Old 12-27-2015 | 12:09 AM
PM Sent and thank you.
Quick Reply: New clutch, round two!
