New CM FX300 Kit I Received Today!
Old 07-28-2006, 10:43 AM
  #301
djt81185's Avatar
fx400 6 puck
Old 07-28-2006, 11:14 AM
  #302
SS4LIfe's Avatar
i was thinking about going to a stg 3 because no one is having a problem with those.
Old 08-09-2006, 03:46 PM
  #303
SStud's Avatar
So i just got the car back from the dealership and now the thing is shifting just fine but as soon as i get into the higher RPM's it won't shift. I know this is the same problem that alot of you guyes are having, but i don't really want to read through all the pages on this thread again. So what do i need to do? It's the FX400 6-Puck, and it did say CANAD on the clutch plate or whatever so i know it's the newer version. Do i just need to let it go for a while and hopefully it'll work itself out or what??? Any help would be great. Thanks
Dave
Old 08-10-2006, 09:22 AM
  #304
PuSha050's Avatar
Dave
yep.. break that sucker in and it will get better.. same thing with my car. there is still a lil bit of air in the system, so double clutch when shifting to get the air out even faster. it may take a lil while for the car to shift good, but it will eventually. mine did this exact same thing and now it shifts great!!
Old 08-18-2006, 06:00 PM
  #305
SStud's Avatar
So i've got almost 200 miles on the new clutch and have been double clutching ever since. How long will this take before i can start shifting in the higher RPM's??
Old 08-18-2006, 06:02 PM
  #306
repoman's Avatar
At least 500 miles on normal break in, but with the Stg 3 6 puck it may take a little longer.
Old 08-29-2006, 11:31 PM
  #307
04redline04's Avatar
I NEED HELP HERE!!!I Was wondering if cm fixed the problem with the fx300 clutch I bought one on august 9 06. The reason why I am asking is becasue about a week back i had tranny issues in my car(Stock clutch,flywheel)And dealer end result was to put a new tranny my clutch was kinda bad so deside to go with findaza flywheel and a Cm fx 300 (so new tranny,clutch,Flywheel) I got the car back about a week from today as soon as I rode the car the clutch needed to be step on all the way im talking about all the way down and then after riding for about a mile i Started to notice a grinding sound when i would decellerate in gears im talking about like a grinding metal to meatal but only in decelleration.Took it back to the dealer and after a day of 2 they told me that the new tranny had a bulletin about a ballbearing and spring problem that needed to be fixed.Mechanic said that the clutch thing could be fix by bleeding it againe.What do u guys think Can it be the Clutch or can it be the tranny issue.Its a brand new tranny,clutch and flywheel thank god dealer did not blame it on the clutch and the tranny is comming down on their behalf.Help me out with What u guys think because if its the clutch I might be in time to send it back get a new one and not have to pay any labor Thanks team
Old 08-30-2006, 12:32 AM
  #308
2K5SS/SC?'s Avatar
If the clutch is grinding you would have noticed it immediately trust me. The whole car shook. If it only happens during deceleration it's probably the slave cylinder or tranny. My slave shirps/squeeks periodically now. Sort of annoying somtimes, but then other times you can't hear a thing.
Oh, and lightweight flywheels also cause a slightly different sound as well IIRC.
Old 08-30-2006, 08:10 AM
  #309
Well thanks. but i think it would sound wierd if the flywheel would sound like rubbing metal just because it light. Dont u think
Old 08-31-2006, 03:05 AM
  #310
SS4LIfe's Avatar
have them check and make sure everything is tight
Old 08-31-2006, 11:04 AM
  #311
triggs21's Avatar
recommend a clutch
I have been having a tearable time with my clutch slipping, when i drop the hammer into second gear it does not engage until the RPM's are extremely low and no matter how much i want to race, i just wont from a dig, it is just too embarassing. my question is i was looking at a SPEC stage III or a CM stage 4 any rec? Thanks
Old 08-31-2006, 11:07 AM
  #312
SS4LIfe's Avatar
i heard the spec is only good if you get the plus one, and i think the CM is cheaper with better grip
Old 08-31-2006, 11:10 AM
  #313
triggs21's Avatar
That is what i heard too about SPEC but enhanced performance recommends the basic stage III and that is what got me confused.
Old 08-31-2006, 11:12 AM
  #314
TurboTechRacing's Avatar
SPEC Stage 3 + is the best IMO, I have it and it is great. We have a good price also on them right now.
www.TurboTechRacing.com
Old 08-31-2006, 11:15 AM
  #315
06black's Avatar
i cant beleve there are still guys with these CM issues.
i can say that this thred made me go spec..GO GO 3+!
good luck to thouse with CM before this i had only heard good things about them.
Old 08-31-2006, 12:01 PM
  #316
360 L337 User
R33P3R007's Avatar
Any more specifics on this clutch
Spec Stage 3+ Cluth Chevy Cobalt 2.0L SS
Old 09-01-2006, 11:56 AM
  #317
PuSha050's Avatar
all i got to say is my CM FX300 is the ****
Old 09-05-2006, 03:04 AM
  #318
CobaltSS313's Avatar
CM FX400 6 puck FTW
Old 09-05-2006, 11:09 AM
  #319
06black's Avatar
yea...
it kicks ass!!!!
but for real...i called spec and they said it was rated for 530ft/lbs at the crank.
Old 09-05-2006, 04:11 PM
  #320
max_boost's Avatar
Originally Posted by 06black
yea...
it kicks ass!!!!
I thought you went with the CM clutch. Good choice on the Spec
Old 09-05-2006, 05:26 PM
  #321
06black's Avatar
where the hell have you been jason?
spec 3+ FTW!
but for real...i went spec after reading this thred.
Old 09-05-2006, 06:07 PM
  #322
max_boost's Avatar
spec 3+ FTW!
Under a rock I guess.
05-28-2022 03:47 AM
biniecki
10-25-2015 02:23 PM
no_ss
10-18-2015 11:58 PM
09-28-2015 12:51 PM
Quick Reply: New CM FX300 Kit I Received Today!
