No Gears
Old 04-10-2022 | 10:15 PM
Alreaxy's Avatar
Exclamation No Gears
I have a 06 ss 5speed and it doesnt go into any gear. i can move the shifter in a complete circle no resistance anywhere. i think can see the shift linkage move under the fuse box. could this still be a rollpin issue? of am i more f***** than i think. i can also move the shifter around while car is running without clutch pressed in.
Old 04-11-2022 | 11:01 AM
Pretty good chance it is the roll pins, relatively simple fix just a bitch to get to. You'll get to get access to the arms and rods to have someone move the shifter while you look at them.
Old 04-11-2022 | 10:00 PM
Alreaxy's Avatar
Roll pin
But don't rollpins usually break while in a gear tho? Is there a easy way to verify that this is the problem?
Old 04-12-2022 | 10:27 AM
Not always, you have to visually inspect the arm and rod on the transmission. If the arm moves but the rod doesn't then its a roll pin.
Old 04-12-2022 | 08:25 PM
63 Nova SS's Avatar
Eric I'm glad you are still around to help newer people.
Old 04-12-2022 | 10:21 PM
I'll still probably be around even though I'm going to be selling my cobalt here in the next couple months (picked up a TDI Touareg).
Old 04-13-2022 | 06:16 PM
Alreaxy's Avatar
What's the arm and what's the rod? There's the 2 pivot points on the trans one for up and down and one for left and right. Those are the arms I imagine. So the rods are coming from the shifter. One of the arms move with the rod for the front to back movement. But not left and right. Does that mean if the trans was good I should have 3rd and 4th gear.
Old 04-18-2022 | 05:06 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Start simple. Pull your cupholders up. Lift the back first (the flat side closest to the stereo). They're real easy to remove.
From there, look down. You should be able to see the shifter cables. See if those are moving or not when you move the shifter.
Driver's side cable is the side to side. Passenger side is for front to back movement. If either one of those isn't moving, then you need to remove your shifter and inspect. Again. Not that hard to do. Report back when you can.
Gabeg
07-01-2016 02:43 PM
CaptainHook
03-19-2015 09:40 AM
tureka
17
10-28-2012 09:03 PM
ayellaone
05-02-2012 11:53 PM
Quick Reply: No Gears
