Occasional Reverse Grind
I have an 05 ss s/c. I've only have it for a few months and sometimes I get a grind in reverse. Mostly if I coast down my driveway in neutral then go to put it in reverse. No grinds or issues in any other gear. And it doesn't do this every time. Any one else have this problem?
if your moving and you put it in reverse it will grind because its not syncroed. need to be at a full stop. if you have it in neutral and just jam the clutch in and jam it in reverse quickly it will also grind because the tranny is still spinning, i generally put it in second then reverse to avoid it.
royce777
09-28-2015 07:11 AM
