Optimal shift points?
2.2 L61
Horsepower: 135 hp @ 5200 rpm
Torque: 142 lb-ft @ 4400 rpm
2.4 LE5
Horsepower: 173 hp @ 6200 rpm
Torque: 163 lb.-ft. @ 4800 rpm
As far as when you should shift, it's really up to you but most people I talk to say even though your power starts to drop off (you're going pass your peak) you may still have a advantage to keep revving because when you shift quickly into the next gear you should drop down right into or around your powerband.
2.4 LE5
