OTTP stage 1 installed
Old 08-25-2010, 02:53 PM
ronn's Avatar
OTTP stage 1 installed..UPDATE TEST DRIVE
Very nice piece!
This is front mount and rear spacer. Torque steer and wheel hop greatly improved.
I found that my stock mount had a TEAR in the center (no biggie) which is in the thinner portion and probably doesn't effect the mounts performance. Car has only 12K mi. I'll post the pic here later on. As far as VIBES..slight increase with AC on only..this will prolly diminish as mount breaks in.
Here is pic of my original torn mount:
Here is OTTP stage 1 kit. Front mount and rear spacer:
Old 08-25-2010, 03:01 PM
vroomvroom's Avatar
i've had mine on for about a month now and i agree - very nice piece! wheel hop almost completely gone.
Old 08-25-2010, 08:25 PM
RYRO14's Avatar
The tear is normal mine had and others have reported it to.
Old 08-25-2010, 08:37 PM
ronn's Avatar
yeah..I think it's really *skin* left over from the mold..nothing functional with the rubber mount itself.
Old 08-25-2010, 10:24 PM
PenguinPIE's Avatar
im interested in this mount to get rid of wheel hop.... everyone said the vibe is minimal but i still have doubts about the vibes because i absolutely dont want any increase in that.. could anyone else with stage 1 mounts chime in about the vibes as well?
Old 08-26-2010, 12:48 AM
ronn's Avatar
See my update.
Old 08-26-2010, 12:58 AM
ronn's Avatar
Test drive OTTP stage 1
It's VASTLY better!!
The real test was to accelerate hard into a very tight turn. Prior to installing this Stage 1 mount, the car would get squirmy with moderate torque steer and some hop. Man..it's now rock solid and I now have MUCH more confidence in squeezing the throttle into tight turns. Under hard acceleration in general ZERO torque steer and very little hop. This mount, even in Stage 1, is awsome. I often drive close to the limit (not speed, but G force wise) and I had trepidations with all this power comming on at once. The mount has pretty much put that top bed. Vibes are no more than stock. I Highly recommend this bolt on to all.
Further udate:
Noticed that drive train *lash* (bucking/lurching)...when on and off the throttle (in 1st 2nd) is gone too!
Old 08-27-2010, 08:50 AM
fredds-turbaltSS's Avatar
Further udate:
Can't wait ill be putting mine in tomorrow. that lash is the most aggravating thing about the car IMO
Old 08-27-2010, 08:53 AM
vroomvroom's Avatar
i noticed zero increase in vibes with mine...
Old 08-28-2010, 02:53 PM
Great mounts, love them. I had a noticible increase in vibes but i like that tooo
Old 08-28-2010, 06:08 PM
ronn's Avatar
Is it stage 1? You shouldn't feel any increase with AC off. Slight increase with AC on. Did you losen passenger side motor mount before installing mount and spacer?
If you notice them (and aren't stage 2), I would make sure you losen up the motor mount on passenger side (3 bolts a couple turns)..then turn car on and back up..move forward. Stop car and re-tighten bolts. See if that helps.
Old 08-28-2010, 10:33 PM
stage 2, only on 1st gear take off, its worse with the AC on yes. but i guess i should reste the front mount huhh
Old 08-29-2010, 01:26 AM
ronn's Avatar
Stage 2 has more vibes. That's why I didn't get it..no need, since I don't drag race. Not knocking stage 2. It's for cars tuned past 300WHP (prolly above 320ish), so it's overkill if you're not in that category (or drag racing). If you didn't loosen that top mount first...you *should* get an improvement after doing so and tightening. Post back if it seemed to help...just curious.
Old 08-29-2010, 11:34 AM
Hugger1975's Avatar
rookie question:
who installs these and what is the process?
I have no clue when it comes to drivetrain
Old 08-29-2010, 11:47 AM
Black SS/SC 06's Avatar
Originally Posted by Hugger1975
rookie question:
You can in your garage lol. Honestly I would have someone do it for you. I had trouble getting things to line up. I have the stage 2 though and fitting the spacers in the bracket for the rear mount can be frustrating. Also the amount of space you have to maneuver around with sucks. Stage 1 should be alot easier.
How to's:
Stage 1
https://www.cobaltss.net/forums/how-guide-43/how-install-ottp-rotated-mount-stage-1-a-154615/
Stage 2
https://www.cobaltss.net/forums/how-guide-43/install-powell-f35-stage2-mounts-166738/
Old 08-29-2010, 12:56 PM
Iam Broke's Avatar
I guess I'll order up a Stage 1 soon, I can always get the Stage 2 upgrade later if I need it.
Old 08-29-2010, 02:53 PM
LNF tuned>300whp...
Old 08-29-2010, 03:07 PM
Iam Broke's Avatar
Yeah, I know I'm around 340 WHP, but I'm on stock mounts now.
Old 08-29-2010, 04:07 PM
ronn's Avatar
You'll love it..makes a signifiacnt difference. For $150 (stage 1), it's a no brainer.
Old 09-02-2010, 01:04 PM
Iam Broke's Avatar
Mine arrived yesterday.... maybe I'll get it in tonight.
Old 09-02-2010, 01:24 PM
coopercharge's Avatar
I have heard good things about the stage 1 mounts. however I went with the TTR Stop mount and only paid about a few dollars less to get both mounts and I must say after the breakin period I was impressed. So I hope that you like the ottp mounts as they do stiffen things up quite a bit. Just my .02. The rotated mounts are awesome regardless of who you go with you will not be disappointed.
Old 09-02-2010, 02:35 PM
Iam Broke's Avatar
Well, not going to happen tonight, have to work until 11p.
Old 09-04-2010, 02:11 PM
Iam Broke's Avatar
Installed today in about an hour, had to move the engine around to get things to line up.
Old 09-04-2010, 03:37 PM
ronn's Avatar
Yeah..did you loosen the top passenger side motor mount first? A must do.
Old 09-04-2010, 04:42 PM
Yea that rear mount can be pretty tricky.
Quick Reply: OTTP stage 1 installed
